FYI: '96 Build Sheet (Of some sort) - Chevy Impala SS Forum
 1Likes
  • 1 Post By threeimpalas
post #1 of 3 (permalink) Old 11-19-2017, 04:45 PM Thread Starter
juniorwatson's Avatar
I thought I'd post this pic to the group as an FYI. I don't recall exactly where I found this on my current ride when I was servicing her at some point in time.
Not a lot of details as others I have found in older cars throughout my life, but I still find it cool to have found something like this that probably doesn't get made anymore.
juniorwatson is offline
post #2 of 3 (permalink) Old 11-20-2017, 10:44 AM
This is the broadcast sheet that gets stuffed between the seat cushion and springs under the passenger side seat.
angelo likes this.
threeimpalas is offline
post #3 of 3 (permalink) Old 11-20-2017, 12:02 PM Thread Starter
Thanks, I never knew what it was called.
