Lower door mouldings - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 03-12-2018, 05:35 PM Thread Starter
I need to replace a lower weatherstrip and have to remove the door bottom trim.
Will I have to pull the interior door panel to get at the nuts on that?
JackFish is offline
post #2 of 5 (permalink) Old 03-12-2018, 08:22 PM
HuSSker's Avatar
No, they are down below the panel area, almost at the bottom of the door. If I recall, you don't need to completely remove the trim to replace the lower strip, just loosen it enough to unhook the seal from it.
I could be wrong though, it's been a long time.
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
HuSSker is offline
post #3 of 5 (permalink) Old 03-12-2018, 09:32 PM
Some of the lower seals have holes that the pins holding the bottom trim go through. The seal clips over the bottom of the door. There is usually a screw on one end, a nut on the other (Phillips and/or 11mm), and three pins that go through grommets in the front, and two for the rear door. It is easier to remove the bottom trim, because you can not tell if the pins go through the seal, or are in a U channel.
Fred Kiehl is online now
post #4 of 5 (permalink) Old 03-12-2018, 10:55 PM Thread Starter
Thanks guys, I'll have a closer look.
JackFish is offline
post #5 of 5 (permalink) Old 03-17-2018, 08:25 PM
Check your PMs.
