91-96 Trunk Lock Cover Fix - Chevy Impala SS Forum
 1Likes
  • 1 Post By gbhs72
post #1 of 3 (permalink) Old 08-01-2018, 06:29 PM Thread Starter
My bowtie that covers my trunk lock is leaning the flip part, does anyone knows of a way to fix this? I heard it's a pretty common problem.
Steven318
Steven318 is offline
post #2 of 3 (permalink) Old 08-01-2018, 07:47 PM
gbhs72's Avatar
My lid and the one I bought to replace it both have this problem. I haven't found a solution. I do have an idea about it though. My thought is to drill a small hole in the corner were the vertical part intersects the horizontal lower left side. After drilling the hole I thought a small roll pin that would protrude just enough to hold it in the proper position and not be too obtrusive. I might have to cut or grind the roll pin a little to make it work.
Mark: Snowman-33
NADACOP likes this.
gbhs72 is online now
post #3 of 3 (permalink) Old 08-02-2018, 07:22 AM
juniorwatson's Avatar
Yeah I've got that problem, and I was thinking something similar like the roll pin idea.
I also thought of using some epoxy in the slot at the end to stop the bow tie from swinging past the normal stop position would be easier.
juniorwatson is offline
