Winter driving - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 11-24-2018, 07:05 PM Thread Starter
Bryceg0401@gmail.com's Avatar
Winter driving
Are these cars meant only for the summer I need my car in the winter and also what do you recommend me do
post #2 of 4 (permalink) Old 11-24-2018, 08:31 PM
I recommend that you spend a ton of time using the search function and learning and stop asking questions. Please do your home work and then when you have legitimate questions then you can get some help!
BH tuning, Transgo shift kit, Eaton posi W/ 3:73 gears, EDGE 9.5" 3000 stall , BMR rear lower control arms. BMR front and rear sway bars Hotchkis springs, CIA trans crossmember; 1.6 Pro magmuim RR; CIA budget headers w/ high flow cats; 2 1/2" cat back with X pipe; chrome dual cone CAI, 52mm throttle body, 30lb SVO injectors, Wilwood brake calipers, Power Stop drilled and slotted brake rotors, Bilstein shocks. Gary's 2 relay headlight harness. Gary's battery relocation harness
my95ss is online now
post #3 of 4 (permalink) Old 11-26-2018, 12:31 AM
TGO
No, they aren't. But if you don't want them to rust then you need to take the proper precautions and wash them often, oil spray the undercarriage, etc. If you think you're gonna drive a 90's car through the winter in the salt/rust belt and not do any extra maintenance then you're gonna wind up with rust holes in the floor and the rear quarters as well as the frame.
2001 Corvette ZO6
1995 Impala SS - H/C/I - BBB
TGO is offline
post #4 of 4 (permalink) Old 11-27-2018, 01:51 AM
The Stickman's Avatar
What's the big deal. This forum like most is dead. If all people did was use the search function this place would simply become an archive site.
And yes these cars can be driven in the snow all you like. No reason they can't be. Good tires make all the difference. I actually run snows on all 4 corners. Helps prevent front end push and lock up. And yes it will rust out a car quicker. Depends on if this is a regular driven car or you "nice" car.
Neil P.
1996 Federal hearse. CAI, Delphi 3.5 MAF, Aluminum elbow, airfoil, coolant bypass mod, 36lbs injectors, LE 223/231 110 LSA cam, Trickflow pushrods, Comp Cams rocker studs, Lunati 1.6 roller rockers,double spring kit and lifters, F-body heads, Cometic MLS .027 head gasket, Hooker headers, Cloyes timing chain, PowerBond balancer, EGR, air pump and AC delete. Solomon tune. CPT Pro-Race trans, 9.5 inch 3200 stall converter, 9.5 inch 14 bolt rear, 4.10 gear and TruTrac helix gear diff
The Stickman is offline
