92 caprice classic basic cheap proformance mods - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 04-13-2013, 03:26 AM Thread Starter
what are some cheap basic performance mods i can do on my 92 caprice classic with a 305smallblock?
tfarr is offline
post #2 of 14 (permalink) Old 04-13-2013, 09:29 PM
1phastss's Avatar
Stock LT1 Cam & New Springs - Headers - Throttle Body Mod - AFPR - area few good starts, along with getting a new chip "burnt"
CarISSMA (Carolinas Impala SS Motor Association) President
1991 White LSX Wagon - (HIS) A.K.A "The Abomination" / Reaper
1991 White SS Wagon - (HERS) SS Nose-SS Wheels-3.23 POSI-Clear Corners-Silverstars-Tinted Windows
ISSCA Member #2499
1phastss is offline
post #3 of 14 (permalink) Old 04-26-2013, 03:35 PM Thread Starter
can you tell me more about the lt1 cam and throttle body mod please?
tfarr is offline
post #4 of 14 (permalink) Old 04-26-2013, 06:36 PM
MEMPH1Z aka 93 CAPRICIOUS's Avatar
take off the mechanical fan and go electric, get a better air breather
1993 chevy 9C1 caprice
MEMPH1Z aka 93 CAPRICIOUS is offline
post #5 of 14 (permalink) Old 04-28-2013, 02:14 AM Thread Starter
i put a cold air intake in im gonna post some new pictures soon
tfarr is offline
post #6 of 14 (permalink) Old 04-28-2013, 09:09 AM
The Lazy Destroyer's Avatar
"Ultimate TBI" mods:
http://www.thirdgen.org/ultimatetbi2
Don't forget the "quarter mod" if you get your intake/exhaust work finished.
Here's a pic:
Cold air intake,
Lots of other ways to do cold-air intakes.
Here is the "Caddy" intake setup on my old TBI car:
Get some stock dual-exhaust pipes from a LT1 ('94-'96) B-car and replace the mufflers with ones of your choice. Many people have these laying around that they'll never use. You will need to get the transmission crossmember modified to accept the other exhaust side. You can also upgrade the stock single exhaust also, without modifying the transmission crossmember.
Stock LT1 exhaust manifolds flow better than stock L03/L05 exhaust manifolds and will bolt up, if you can get the "y" pipe modified to fit.
If you don't need smog requirements, you can always gut the cat(s)
Delete the air pump and re-route the belt. Unlike LT1 cars, the air pump on the L03/L05 is belt-driven. If it's removed you can use an alternate belt routing.
As mentioned, upgrading to electric fans can free up some HP too, and can also really clean up the engine bay and allow easy access around the front areas.
Stock LT1 cam can be had for next to nothing, and makes a good performance cam (without getting too crazy) for TBI cars.
Lots of other options but you start to leave the free/cheap area.
-Blake
________Motoception Photography________
"Those who possess power define those who are powerless."
95 Caprice 9C1, 12.9 @ 103 mph, 1.74 60' - Bolt-ons car
96 Caprice Wagon - "Nomad SS"
94 RMW woody
The Lazy Destroyer is offline
post #7 of 14 (permalink) Old 05-06-2013, 10:42 PM
If you put a 350 in it you will get 180 HP and 300 lb.ft. of torque. If you put a 350 from a 91-93 9C1, you get 205 HP. Used ones are about $350 at the pic-n-pull junk yards. They bolt in, but you need the computer for about another $50. The 9C1 has a similar cam to the LT1. Larger 9C1 Y pipe, and exhaust system (you can get the cam, injectors, computer, and exhaust for your 350 to make it a 9C1 350).
Put an extra gasket under the injector holder on the TBI to open the intake path.
3.23 gears will make it feel like it has more power, and will not affect your gas mileage. The gears in the VSS will have to be changed to match the gear ratio/tire size.
If you are going to install a cold air intake, move the charcoal canister under the wheelhouse with the bracket from a 94-96 (found on the opposite side).
The dual fans from a 93 FW are a perfect fit, and you only have to figure out how to turn them on. Temp sensor with switch, and AC clutch...have them run by relays. Electric fans will give you about 5 HP.
From here on, you are going to have to get the computer chip burned.
You can use the larger TBI from a 454, and the injectors from a 9C1. You will have to bore the intake out so there is no lip where the TB and the manifold meet. You also have to get the larger gasket set, or open the holes on a set for the smaller TBI. The connector for the cruise control is larger on the larger TBI, and you will have to ream the end of the cable as well as a larger clip. Adjustable fuel pressure regulator, and fuel lines from a LO3/5 equipped 91, 92 or 93 FW with Schrader valve for a fuel pressure gauge installation.
Cam of your choice, springs, rockers, etc.
Headers (about 20 HP), duals, and modified trans crossmember/redesigned crossmember for duals.
Reasonable expense for another uprade is a 350/5.7 Vortec engine from a later truck with its wiring harness, computer, and possibly the transmission. You will have some wiring adaptation, and maybe the FEAD, or use the one from the LO3 if the bolt holes match. You might need a stronger fuel pump, and a reprogram for the computer. Cam, headers, valve springs, duals, trans crossmember mod, are all doable with a Vortec engine as well. The engine should be the same price as a 9C1 at a pic-n-pull yard, just a little more work, because of the different wiring. You can make more HP with less money with a Vortec than you can with an LO3/5.
Next step up is the LS series engines and matching trans.
If you do it yourself, the mods are relatively inexpensive. If you have someone do it for you, it can get expensive fast.
Fred Kiehl is online now
post #8 of 14 (permalink) Old 05-12-2013, 07:58 PM Thread Starter
ive done the caddy intake and im gonna be moving the charcoal canister soon i have to go get the bracket. Im going down to pull a part and getting the 350 from the police package once i get the money. my buddy said when he did the quarter mod on his car he lost alot of power. the electic fans will probably happen when i have the engine out and swapping it. if anyone knows anyone with a 9c1 cluster for a reasonble price let me know please. thanks alot for the advice. im new to the bbodies but im part of INC so alot of guys that can help.
tfarr is offline
post #9 of 14 (permalink) Old 05-12-2013, 08:26 PM
The quarter mod should only increase your fuel pressure a little. Maybe 2-4 PSI. Most of the LO3/5s are low on pressure to begin with, so it should only help.
To upgrade your LO5 to the 9C1 spec, you only have to get the cam injectors, computer, and exhaust/install duals...then you need a modded trans crossmember, and a second muffler bracket for the driver's side. A second left bracket bolts to the right side like it was made for it.
If you need a 9C1 cluster, you also need the dash. The Caprice dash has the idiot lights, that cover some of the cluster. There is/was a 9C1 cluster in a car about 35 miles from me. I am headed there on Memorial Day weekend. If you want it, I will get it for you. You are looking at about $50 shipped. If you want it now, the price is $80 shipped.
post #10 of 14 (permalink) Old 05-12-2013, 09:20 PM
I think he has the civvie 305 per his original post. This would be the norm for a non-9C1 TBI car for '91/'92. '93 350's could be had in non-9C1's via the LTZ package, albeit in a less powerful version.
-Blake
94 RMW woody
