LT1 into 1996 L99 ? - Chevy Impala SS Forum
post #1 of 16 (permalink) Old 05-25-2013, 06:19 AM Thread Starter
LT1 into 1996 L99 ?
As my other post, picked up a 1996 with a 4.3 L99
Just wondering whats involved in swopping a LT1 into it ? As the L99 is a baby LT1 fitting wont be a prob, but would the engine management systems be different ? And headers ect ? Transmission ?
Would much else need changing or is it a simple swop
After owning a 95 Z28, feel the Caprice needs a bit more bhp !
57peppershaker is offline
post #2 of 16 (permalink) Old 05-25-2013, 07:51 AM
Banned
You would have to have the PCM re-programmed. If you have a 96' LT1 PCM lying around, you will have to re-program the PCM for the final drive. I believe 96' L99's had 2.93's.
Also if you do not already have an external transmission cooler, upgrade to one now.
It would probably be a good idea to swap the oil cooler delete adapter from the L99 to the LT1.
-LT-
jcarenza10 is offline
post #3 of 16 (permalink) Old 05-25-2013, 01:52 PM
Been there, done that on my 95 l99 Caprice. When I did my swap, I had the complete drivetrain including the PCM. All Boltons for the lt1 will fit an l99 and vice versa. Not sure if the trannies are different between cars or if its geared or different electronics in the Trans. The l99 uses 19 lb injectors and the lt1 uses 24's. the fuel rail and reg are the same as most Boltons are except for the alternator which is 140 amp as opposed to the 105 amper on the l99.
Engines are pretty much the same, just be sure to get an lt from a 96 since yours already is odb2 and not odb1 setup which uses a crank sensor and 2 additional o2 sensors. The rear in my l99 car was a little 7.5" open rear and when I swapped in a larger 8.5" from another car I also had to use the driveshaft which is a little shorter due to the larger pumpkin.
Last thing to consider is the exhaust. Yours most likely has single exhaust from the back side of the cats. If you want to run a true dual exhaust, you may also want to pick up the heat shields for muffler and gas tank along with hangers for the other side if you add it.
Edit - on the engine oil cooler. Not sure why so many are against these. The only real leak prone area is the rubber hoses on the hard lines. This is an easy fix with some new connectors and different hose of your choice. I added the external 9c1 cooler which bypasses the rad cooler and mounts up front next to the ext. tranny cooler. I think it helps to balance the look of the front a little with both coolers there. My car also did not have the ext. Trans cooler and I added that as well using all stock GM parts.
post #4 of 16 (permalink) Old 05-25-2013, 03:14 PM
Banned
I also added an external transmission cooler to my 94' LS Civilian. However, I ran it through both the original internal radiator and the new external radiator. All three 9C1's in my hands were routed this way so I have to believe this was the stock cooling route.
post #5 of 16 (permalink) Old 05-26-2013, 10:17 AM
Same here and i think i remember seeing some where that it is benefitial to still run it thru the in tank cooler as well. I would suspect that the OP's car may just use the in tank tranny cooler in the rad. My 95 civi never had the external Trans cooler. This was one of my first mods many years ago. Even with the l99 engine which I ran for 100k plus miles, I wanted to add a little extra cooling for the Trans.
Iirc - it was a pretty easy addin from a donor car. I just grabbed all the metal lines and brackets for the external setup. It just runs in "series" with the in tank cooler. I may have had to modify one of the existing lines/hoses, but I'm sure it was an easy mod.
post #6 of 16 (permalink) Old 05-26-2013, 11:23 AM
Originally Posted by Marky Dissod on May 25th 2013 @ 01:08 PM View Post
Pretty much what jcarenza said.
96 L99s had EITHER 2.93 (civilian standard), or 3.23 (civilian option, 9C1 standard).
With an LT1, an external transmission cooler is pretty much mandatory. You can probably do better than OEM for less money.
It's a great idea to swap the oil cooler delete adapter from the L99 to the LT1; it's a potential source for leaks and coolant contamination. If you drive very hard, often, you may want to consider 0W30, 5W30, 0W40, or 5W40 synthetic motor oils.
on the engine oil cooler. Not sure why so many are against these?
Not so much 'against', just can't think of a reason to be 'for', unless vehicle is used as hard or harder than a police pursuit vehicle/taxi/etc.
With the OEM fan-on settings, yea, I could see an external oil cooler being a necessity, especially if using cheap 'dino-press' motor oil for extended service intervals, driving hard for extended periods, etc.
I use 0W40 Group4 synth and change it every 5000, the lowest reasonably possible fan-on settings regardless which thermostat I'm using, etc, and while I do drive like a d!ck often, I'm getting better at using the gas & brake less, and coasting more.
The vast majority of people here still using an external motor oil cooler would be wise to repurpose it as an additional external transmission oil cooler, as the transmission would get more longevity/durability out of it than the engine.
They are NOT Lying to You
You are NOT Lying to Yourself
Marky Dissod is offline
post #7 of 16 (permalink) Old 05-27-2013, 12:01 PM
Although additional coolers are always good, why is the external transmission cooler so vital for these cars compared to others? The LT1 isn't so powerful (in stock form, we're talking) as to put that much stress on the transmission, not unless the tranny is not a great design (I've heard it's pretty good in general). I mean, my G8 doesn't have an external transmission cooler, and it has a ton more power rushing through it compared to a '96 Caprice LT1 . Same goes for the oil cooler, really.
1996 Caprice Classic: LT1, B4U, DCM/ruby cloth; stock except for side trim removed
2009 Pontiac G8 GT: maverick silver/onyx cloth; mods: Solo Mach catback + resonators + HFCs, AEM short ram, Livernois ECM/TCM tunes
Turbo301 is offline
post #8 of 16 (permalink) Old 05-27-2013, 06:24 PM
Banned
The 6L80-E and the 4L60-E are completely different animals. Just like the LT1 and LS3 are two completely different engines. There is no basis for comparison.
-LT-
post #9 of 16 (permalink) Old 05-27-2013, 07:04 PM
I don't know if I would say they are vital. Probably plenty running with just the rad cooler and are fine for many miles. A good maintenance program for fluids changes is most likely all you really need. A plate type aftermarket cooler is most likely the better way to go for cooling if you drive your car hard. For my needs, I prefer the stock style setup for looks and ease of setup since its all factory stuff. The extra cooling and fluid capacity is a plus.
Unless a car is driven hard or used on the track, you would be fine with standard cooling. Even though I don't track my car, I do "feel" the additional cooling can only help and sure doesn't hurt. Is it needed, probably not, but if i have the chance (good used/new parts) to add some extra cooling and it also factory, why not? I even added the ps cooler setup when I swapped my steering box. Again is it needed...no....but I just like to add things like this since its factory and a little extra never hurts.
post #10 of 16 (permalink) Old 05-27-2013, 08:36 PM
91ss's Avatar
Like was said, if you're all stock, you DON'T need a cooler. If you do a lot of hard stop and go driving eg nyc cabs, police service, then that is what starts heating up the fluid. It's the converter slip that causes heat. Higher stall converters, yes need more cooling as they generate more heat.
I get out onto the highway before the engine is even up to temp. The tranny will get up to about 150-160 and would stay there all day long as the converter is locked up. It's my normal commute. 1/2 mile after getting off and it's up to 180 if I hit all the lights. I added a cooler because us engineers like a good safety margin if allowed
Here's a good table from TCI. With more and more modern fluids, I'm sure the numbers are even higher these days before there are fluid issues.
http://www.tciauto.com/tc/trans-life-expectancy
Oh, and too cold can hurt. The converter is typically kept from locking up until a certain temperature is achieved.
91ss is offline
