Vehicle speed sensor - Chevy Impala SS Forum
post #1 of 34 (permalink) Old 05-30-2013, 02:42 PM Thread Starter
Hi guys,
Does anyone know the GM parts number of the vehicle speed sensor of a '91 Chevrolet Caprice? Mine is busted and at rockauto.com there are several speed sensors.
Many thanks.
1962 Cadillac coupe deville
1991 Chevrolet Caprice wagon
imported_zorrodeporro is offline
post #2 of 34 (permalink) Old 05-30-2013, 02:51 PM
91ss's Avatar
Got mine from there. You have to match up the codes they show with the the SPID label.
91ss is offline
post #3 of 34 (permalink) Old 05-30-2013, 03:45 PM Thread Starter
Thanks, but there are lot of numbers in the SPID label, so how do I do this?
post #4 of 34 (permalink) Old 05-30-2013, 05:39 PM
91ss's Avatar
Pretty simple. They're in alphabetical order. If you notice in rockauto, they are looking for a D8something, like D8E, D8N, D8I etc.
They along with the speedo gear are different for different axle ratio/tire combinations to get the speed right. Hopefully, your axle is original and tires are about stock height.
91ss is offline
post #5 of 34 (permalink) Old 05-30-2013, 09:14 PM
There are two different types. One is for 40 plus tooth driven gears, and the other is for less than 40 tooth driven gears.
Here is a resource: http://www.transmissioncenter.net/ go about 1/3 of the say down the page to "speedometer world" and click on it. About 1/4 of the way down the page are the 700R4 VSSs and gears.
If you are going to just replace the VSS, you have to know how many teeth are on the driven gear before you buy a new VSS. They are color coded for size (I can look it up for you). If you are going to change tire size, or rear gearing, a couple of the gears are not available.
Fred Kiehl is online now
post #6 of 34 (permalink) Old 05-31-2013, 06:33 AM Thread Starter
Thanks guys for the input. I took some pictures of labels but they are all pretty bad. Can anyone figure them out? I got a stock '91 5.0 V8 Chevy Caprice wagon with stock tires.
Thanks again.
post #7 of 34 (permalink) Old 05-31-2013, 07:54 AM
With the GU2 rear (2.73) and 225/75/15 tires, according to the FSM, you should have a 36 tooth (white) driven gear. That means you need the VSS for the smaller than 40 tooth gears.
post #8 of 34 (permalink) Old 05-31-2013, 02:04 PM
91ss's Avatar
SPID says D8N. That is the reference to use on rockauto. Fred's link shows two housings but both are for cable driven speedometers. My 91 sedan does not use a cable. The housing is flat.
91ss is offline
post #9 of 34 (permalink) Old 05-31-2013, 02:14 PM
The reference also shows electric VSSs.
post #10 of 34 (permalink) Old 05-31-2013, 02:23 PM
91ss's Avatar
Ah, yes see them down further.
91ss is offline
