CAN YOU PUT GRANT STEERING WHEELS IN 96. caprice - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 06-25-2013, 01:11 PM Thread Starter
I have a 96 caprice bone stock I want to put gt grant steering wheel in it. Can I do it if I find kit ?? Nd I dont want to set off air bags in process..
96pricerunning is offline
post #2 of 3 (permalink) Old 06-25-2013, 01:25 PM
Can you put grant steering wheels in a '96?
Of course,but the air-bag has to come out,followed by the factory wheel. Pretty sure I used a GM install kit (pre-airbag),but it's been a while.
post #3 of 3 (permalink) Old 06-26-2013, 11:11 PM
96LT1GUY's Avatar
FWIW I have an 80's caprice steering wheel in my '96.
My airbag light is still on ( haven't popped it out yet )
Disconnect the battery, WAIT like 10 minutes for the SRS system to "de-energize", that way you don't get punched in the face with the airbag.
Undo the torx screws on the back side of the steering wheel.
Remove air bag and the wire with the spring (the name escapes me)
Remove hold down nut.
Remove the steering wheel with a puller.
Install in reverse.
Don't forget to torque the big hold down nut. The specs are in the FSM. I don't remember off the top of my head.
I had to drill a hole to allow the airbag (unused) harness to tuck inside the horn pad incase I want to reverse everything. Horn works as it should.
IIRC most 70's-90's applicable aftermarket kits and wheels will work.
Most companies won't list our years because of the airbag. Basicslly, if it'll work for a box caprice, it'll work on a '96.
But, there are many options out there.
-BRIAN-
1988 9C1
1989 9C1
1994 RMS Limited
1996 9C1 built 9/27/95 Former L.A. MTA/LASD Court Service Division #SD/R01413, 5662/PPM autox springs, ZQ8, Belltechs, posi/3.08, shaved trunk lid w/spoiler, Buick brace, BMR tubular extended U/L RCA, cowl hood, Lil Ron's 91/92 tails, K&N CAI, TB bypass/bleeder valve mod, stealth bolt/bolt II mod, SEO 7X7, console shifter, leather buckets, prisoner locks, '86 steering wheel, manual interior, '66 emblems, American Thunder, 17x8/17x9 REV Classics
96LT1GUY is offline
