'94 Caprice blower motor resistor replacement - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 07-14-2013, 01:50 PM Thread Starter
Can someone give me some info as to replacing a blower motor resistor on a '94 Caprice? Thanx in advance.
mictat2214 is offline
post #2 of 6 (permalink) Old 07-14-2013, 02:28 PM
jayoldschool's Avatar
Remove lower hush panel (clips simply squeeze). Unplug harness connector. Remove two 7mm (probably) screws, take out resistor module. Reverse directions to reassemble.
jayoldschool is offline
post #3 of 6 (permalink) Old 07-14-2013, 04:41 PM Thread Starter
Hush panel? Thanx for the reply.
post #4 of 6 (permalink) Old 07-14-2013, 10:52 PM
The piece of plastic above your feet on the passenger side under your glove box. It has foam on the back to hush noise ;-)
post #5 of 6 (permalink) Old 07-15-2013, 06:40 AM Thread Starter
Okay. Thank you for the info.
post #6 of 6 (permalink) Old 07-23-2013, 10:44 AM Thread Starter
Hey! J.O.S. Thanx for your help. 10 minute job. Betcha I saved mucho dinero by D.I.Y. fix. Final cost = $21.95!!!
