Need Help here... Picked up a 96 impala and think it may be a 95 or a 95-96 caprice. - Chevy Impala SS Forum
post #1 of 63 (permalink) Old 07-23-2013, 06:20 AM Thread Starter
bigakphilly's Avatar
I never thought I'd actually be confused about this topic in my life. I just picked up a 96 impala SS. It's off a friend of a friend. If the car is a fraud, i don't think the kid knew or did any of the work.
I think this car is a 95 impala or it is a 95-96 Caprice that just so happened to be black with grey interior. I am mainly leaning towards a 95.
Tell me what you think:
List of shady things about this "96 SS" that makes me think its a 95:
1. The Speedo Cluster does not work. It is a 96 cluster. I understand they go bad, but when I put the key in and put it on the ON position, only like 3 idiot lights come on for a second. CHECK ENGINE not included. My question is, if i were to put a 96 cluster in a 95, what would and wouldn't work in it?
2. The Shifter/center console. It does have a 96 cluster and console in it. Problem is that the SHIFTER assembly is the only thing that is bolted down. The console itself is not bolted down, and i can just lift it over the shifter. I think it was a conversion.
3. There for SOME REASON is a 94-95 steering column in it. It has an aftermarket stainless steel steering wheel. But it has the NUB on the column sticking out where the gear lever would be. Very strange. Don't know why someone would put a 95 column in a 96 impala. Also does NOT have a chip in the key
4. The car was stolen during the period the 2nd owner had the car. I bought the car off of the 3rd owner, so i know it was not his fault. Anyway, the VIN number had to be legally replaced. So he did that. So there is a new VIN Plate in the dash. Its blue. Actually looks like a newer car vin plate.
5. THere are weird body differences. The passenger fender does NOT have a spot for the antenna. Its either been shaved, or maybe the 96 never came with one.
6. The door handles on the driver door and front door have NO keyhole. No spot for a key to unlock and lock your doors manually. Never seen that in my life.
7. Headlights are caprice headlights, and not impala headlights. No black strip on top of the lights.
I am at just a loss here. All the usual suspects are here, and they look STOCK as if it was like this from the dealer. Rims, Springs, Emblems, Trunk Emblems, interior color, interior itself is all impala interior. Auto dim rear view, map lights in back seat, change holder and T/S headlight switch.
Any advice would be great. Thanks
I never lie because I don't fear anyone. You only lie when you're afraid. John Gotti
https://www.facebook.com/al.kleister
bigakphilly is offline
post #2 of 63 (permalink) Old 07-23-2013, 07:08 AM
91CapClassic's Avatar
If it was stolen at one point it's possible that the owner pieced back together as cheaply as possible therefore mixing and matching parts without much regard for having the correct parts. Who knows what damage was done during the theft but we know at least the column would have been busted so that'd explain the odd column you have. It was available and works so they slapped it in. Say there was other misc damages you could easily explain the headlights and what not. So I'd bet you have a '96 that was just poorly reassembled after the theft.
In the Garage:
1977 C-10...full restomod and my ever evolving project
1991 Caprice...https://www.impalassforum.com/vBullet...d.php?t=274326
2007 Suburban...Wife's DD with a nice list of mods that continues to grow
I have build threads on all of these. Just ask
91CapClassic is offline
post #3 of 63 (permalink) Old 07-23-2013, 07:35 AM
ImpalaSSpeed96's Avatar
Send a message via AIM to ImpalaSSpeed96
Run the VIN, or easier, make sure the SPID on the trunk reads WX3 in there and there should also be one on the door. But definitely the trunk. Guys never go to the hassle of getting a SS trunk lid that has the WX3 sticker on it. If it's gone, I'd bet it's a caprice. But, run the VIN. You can do it on a few sites for under 5 bucks.
95 6-speed DCM SS- "LSXT56" [email protected], 1.91 60'
96 DCM [email protected], 1.74 60'- Bro rocks it now
07 Silverado 6.6 DMax- Standby
15 Sonata-The DD
Timmay!
ImpalaSSpeed96 is offline
post #4 of 63 (permalink) Old 07-23-2013, 07:37 AM
There are a lot of tell-tale signs in a Caprice vs. a Impala. some that are more subtle than others, but if done right its hard to tell. I've seen some cars sold as an Impala with a lot of clues it was a Caprice. Maybe post up some pics of what you got.
Obviously the VIN is one way to determine what you got and also the trunk lid codes but keep in mind the trunk lid could easily be swapped too.
One thing for certain is only the Impala's had the Floor plate for the console welded to the floor. The center console is pretty easy to remove like you said, why not just pull it out and look for the plate and make sure it is one that was not welded later or bolted to the floor. but if you have a theft recovery vehicle, there is no telling what the Insurance company, old owner and/or repair shop did to get her back on the road. With part interchangability on these cars.....anything is possible.
post #5 of 63 (permalink) Old 07-23-2013, 08:05 AM
If the VIN has been replaced with a new VIN and it's not the factory VIN then that may not be 100% accurate I wouldn't think.
In the Garage:
post #6 of 63 (permalink) Old 07-23-2013, 08:33 AM
SStreetking94's Avatar
I would try a couple different things. Carfax, get an online insurance quote. It should tell u what that vin comes back as. Try hooking a scan tool to it. The vin that comes up in that scan tool should match the tag. If not, do the insurance quote with the one that comes up on the scan tool. Even still could have a swapped pc. The nub in the steering column sounds suspect.
tb mod,comp cams 1.6:1 roller rockers,comp cams pushrods, dynomax cat back,ngk tr55 iridiums,k&n kit and accel distributor.
SStreetking94 is offline
post #7 of 63 (permalink) Old 07-23-2013, 09:32 AM
Yes, that would be another indication this is not a 96 Impala.
But, it is possible that thieves busted up the column so badly in stealing the car, that the shop/owner/insurance got a used part and made it work. 96 columns are no where near as easy to find as a 91-96 Caprice column.
Anything is possible at this point when it comes to bolton items. That's why I was wondering if there was a shift plate (since he indicated the console was not mounted) that was factory welded to the trans tunnell. That would be hard to replicate with the spot welds and then factory paint on top of it....at least correctly.
post #8 of 63 (permalink) Old 07-23-2013, 09:37 AM
My thoughts exactly which is the basis for my original post. It's entirely possible that what he has is a '96 Imp but the damage was "repaired" with random parts that are now raising questions.
In the Garage:
post #9 of 63 (permalink) Old 07-23-2013, 11:26 AM
The car sounds a bit shady just from a "questionable used car" point-of-view, not even considering the Impala vs. Caprice thing.
There should be lock cylinders on the doors, and yes, you could get a power antenna in '96 (damned, EVIL things - power antenna is the dumbest idea ever...). I thought all Impala SSes had power antenna, but I'll defer to the experts on that.
I don't get this one: is there really a difference between Caprice and Impala headlights? To what "black strip" are you referring?
Other than the trunk lid (which is presumably off of an Impala regardless), will the WX3 code appear on other identification on the car? Definitely check that.
Considering that the Impala package was just an option on a Caprice, and as long as you didn't pay big money for it (which, with the problems it has, I'm assuming you didn't), then "real vs. fake" likely isn't too important.
1996 Caprice Classic: LT1, B4U, DCM/ruby cloth; stock except for side trim removed
2009 Pontiac G8 GT: maverick silver/onyx cloth; mods: Solo Mach catback + resonators + HFCs, AEM short ram, Livernois ECM/TCM tunes
Turbo301 is offline
post #10 of 63 (permalink) Old 07-23-2013, 11:51 AM
thebigbadWOLF's Avatar
the impala head lights have a black strip along the top of them.
Cali-SS
thebigbadWOLF is offline
