Crossmember fitment - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 07-25-2013, 09:23 PM Thread Starter
Crossmember fitment
Wat needs to be done to get a 94 caprice crossmember to fit my 89 chassis.the crossmember in question is made for dual exhaust.
Shttn89 is offline
post #2 of 5 (permalink) Old 07-26-2013, 03:38 PM Thread Starter
nobody knows???
Shttn89 is offline
post #3 of 5 (permalink) Old 07-26-2013, 04:34 PM
Crossmember fitment
It's not an issue that comes up a lot.
post #4 of 5 (permalink) Old 07-26-2013, 10:26 PM
It may be easier to modify your original crossmember for duals. I used a piece of a crossmember from the junk yard. Get a piece about 10 inches long, cut in half to make a channel, then taper and the fold the ends down. Make it to fit between the original tube and bottom of the floor pan with about 1/8 of an inch minimum clearance. Weld the piece to the top of the tube, and weld any open edges. After welding it to the top of the tube, cut the bottom of the tube up to the bottom of the top of the original tube making a hump in the crossmember. Cut the tube at an angle to match the path of the exhaust pipe under it. Fill the open ends of the tube with parts of the left over tubing by cutting to size, and welding the pieces in the ends, sealing all edges. Mine is done that way for my 91 OCC, and yours should be almost identical to mine. You do not need a jig to hold it, because it will not warp if you follow my instructions above. You can buy ready made crossmembers for about $150-250 if you check around.
The 94-96 crossmembers require you to flatten the top of the left pipe to go under it. You can make your OEM crossmember to allow the full height pipe go under it. Your tubular one is lighter than the 94-96 as well.
Fred Kiehl is online now
post #5 of 5 (permalink) Old 12-11-2013, 03:35 PM
one of the diff between the '77-'93 frames and the'94-'96 is the tranny x-member. On the pass side the mount for it is about 8" farther back than on the earlier cars. The squared off part extends back at least 8"
Impala77 is offline
