1995 Caprice Wagon Cooling Fan Not Running - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 07-26-2013, 10:53 PM Thread Starter
Hi guys I am back! This time with a 95 caprice wagon "SS". So I noticed the other day idleing that the car was starting to run HOT and continued until the temp was into the red, the cooling fans NEVER kicked on 0.o
So I first off removed the plug to the front temp sensor on the water pump so the car would go into open loop and turn on both fans, which it did. My question is guys where should I start to try and find my problem? Coolant level is perfect no air in the system. There is however one thing I have noticed, and that is the car has a Bypass pulley for the Air Conditioning. Could this have something to do with the fans not responding? The wires are just laying there from where the A/C compressor was at.
allmiller4u is offline
post #2 of 3 (permalink) Old 07-27-2013, 01:55 AM
sounds like coolant temp sensor is bad ,get an ohm check on it
here is info I got on standard motor production
T-Series; Thread Size - NPT: 3/8" - 18 Thread; Blade Terminals; Terminal Gender: Male; Temperature Rating: 1305 Ohms @ 100 Deg. F, 61.9 Ohms @ 245 Deg. F
take it out from water pump,plug it at water pump
drop it in water ,ohm check it at different water temp,see if respond correctly
you may get away with cleaning it up,if that dose not work, new one is about 15 to 22 $
when you don't know what to do,do what you know
ahoora is offline
post #3 of 3 (permalink) Old 07-27-2013, 05:50 AM Thread Starter
awesome info I was going to ask what my Ohms values where for the sensor! thanks a ton I will repost to let you know how it goes!
