4.3 V8 upgrades? - Chevy Impala SS Forum
post #1 of 27 (permalink) Old 10-28-2013, 11:33 AM Thread Starter
bd2022's Avatar
4.3 V8 upgrades?
Curious if there is any performance or dress up kits for the 265 V8 lil guy?
Chad
94 caprice bagged and bodied on 20/22
bd2022 is offline
post #2 of 27 (permalink) Old 10-28-2013, 12:47 PM
Swapping it for an LT would cost about the same as trying to dress up the L99. You can get a good LT1 in a u-pull-it for about $300. Just make sure it has lower mileage. You can swap all of your good parts to it, and return the rest to the yard as the core. Remember to get the computer for the LT1. (The computer for the L99 will run the LT1 if you want to use it. Stock class racers use them)
post #3 of 27 (permalink) Old 10-28-2013, 01:45 PM Thread Starter
bd2022's Avatar
LT is an option, kind of attatched to the 4.3. Mostly based on it has just under 79k, well maintained great running motor.
Thanks for the info!
Chad
bd2022 is offline
post #4 of 27 (permalink) Old 10-28-2013, 04:41 PM
I had the L99 in the Caprice for many years before going with an LT1. Over the years, I added just a K&N FIPK for the lt1 cars. I also added a true dual Flowmaster catback was also added to the 4.3 without any issues or tune. Not much else I wanted to do with the little engine and neither K&N or Flowmaster would say if their kits would work or cause problems on the 4.3, but both were fine and a true bolt on.
As mentioned, the 2 engines are externally identical to each other. The nice part about these mods is they are also compatible with the LT1. If you do decide to add the other side exhaust, keep in mind you will need heat shields and hangers for the other side.
post #5 of 27 (permalink) Old 10-28-2013, 05:00 PM Thread Starter
bd2022's Avatar
Car already has dual exhaust, not a great job done. Has manifolds, would LT headers work?
Chad
bd2022 is offline
post #6 of 27 (permalink) Old 10-29-2013, 06:14 AM
To put it briefly, again, YES.
Ditto.....the exhaust manifolds are the same so Headers should bolt right up.
Back when I first did mods to the L99, it was my first crack at modifying a Computer controlled car. My only concerns at the time were "will this cause problems with the ECM since these were all designed for a 5.7 engine?". I could not get the vendors to verify if their 5.7 kits would cause any problems or not.....they had no info on the 4.3 and would not speculate one way or the other. So it was up to me to "just try it" and see.
As far as headers, just like the Dual exhaust I tried at the time, I think you will find they will fit and you just have to go for it and see if the ECM doesn't like it. But my gut tells me you will be fine. I didn't add Headers until I swapped in the 5.7, but they were on my list to add before the engine swap, just never got to it.
But realistically, how much performance you looking to get out of the old 4.3? As was mentioned, the 5.7 swap gives you more bang for your buck and certainly a bigger smile. I will add that the 4.3 I had served me well for nearly 120K (carefree) miles. When I sold it, it was still in great shape and never burned any oil.
post #7 of 27 (permalink) Old 10-29-2013, 08:12 AM Thread Starter
bd2022's Avatar
Not looking to put it on a drag strip, just a little more pep would be nice.
Chad
bd2022 is offline
post #8 of 27 (permalink) Old 10-29-2013, 09:32 AM
You want more Pep from a 4.3 , the mods mentioned will maybe give some benefit. No numbers to back this up and it could have been a Placebo effect with the car at least sounding better with Duals and looking better in the engine area with the CAI kit. Doubt there was much real world difference.
If you plan on keeping the engine and really want to see some Pep out of it, consider changing the rear gears. My original rear was a puny 7.5" with a 2.92 gear. Drop in a larger rear from an Impala/Caprice with a 3.42 or 3.73 and be prepared to smile more. Keep in mind that if you do this, you may need to also swap the drive shaft as the one for the 7.5" Pumpkin is too long for the 8.5" Pumpkin.
post #9 of 27 (permalink) Old 10-29-2013, 09:46 AM
Firewood's Avatar
Nitrous!
_______________________
Firewood is offline
post #10 of 27 (permalink) Old 10-30-2013, 09:19 AM Thread Starter
bd2022's Avatar
Smile
lol, I have 2 kids.....no more bottles!
Chad
bd2022 is offline
