Touchy steering? - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 11-03-2013, 07:27 PM Thread Starter
xx96CapriceLT1's Avatar
Touchy steering?
So, when I bought my 1996 Caprice, the steering was a bit off. We thought this was the result of a broken pitman arm seal. We found out that it was also leaking power steering fluid. We replaced the pitman arm seal, had it aligned, and it no longer leaks fluid, BUT, I have noticed, mainly on the highway, that the steering feels a little touchy. It sways a bit at certain speeds, there's a noticeable area in the middle where the wheel steers freely, but doesn't really control the tires. I have to hold the steering wheel to the right slightly just to keep it straight. I'm not sure if it has to do with the front shocks or what. Has anyone else had a similar problem?
xx96CapriceLT1 is offline
post #2 of 6 (permalink) Old 11-03-2013, 09:42 PM
Maybe the steering box has some wear? What's the mileage?
Huggies is offline
post #3 of 6 (permalink) Old 11-03-2013, 09:50 PM Thread Starter
Currently 199k approximately.
post #4 of 6 (permalink) Old 11-03-2013, 09:50 PM
Mr pogo's Avatar
sounds like your steering box travel is not centered when in the straight ahead position.
basically the steering box has to be in the center of travel where the sector is tightest, the tie rods and steering wheel are then adjusted so the front wheels are straight ahead.
Mr pogo is offline
post #5 of 6 (permalink) Old 11-04-2013, 07:38 AM
streetcar2try's Avatar
I just had mine aligned and did the jeep shaft swap. Mine has always been very touchy. I have to re align it becasue my alignment guy has it tilting slightly to the left. It irritates the **** outta me. But any slight movement and it will change lanes on you if you're not careful.
My possible winter project might be rack and pinion though.
94 ImpSS, Currently a 24x 383 LTx. Built by Me.
Machining by Competition Automotive & Machine
Harness by BP Automotive (Bill)
Tuning by James at Shortuning.com
Mike Harris Crossmember
much, much more....
streetcar2try is offline
post #6 of 6 (permalink) Old 11-04-2013, 09:19 PM
Your steering is sloppy in the center, because the box either needs adjustment, or is worn out. The procedure is on the forum, if you want too search for it. It is also in the FSM.
Fred Kiehl is online now
