What is this part? - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 03-21-2014, 07:58 PM Thread Starter
What is this part?
I found it loose up under the steering column.
Is it just a wire loom of some sort? Or ignition switch part?
JackFish is online now
post #2 of 9 (permalink) Old 03-21-2014, 08:14 PM
91ss's Avatar
I know I've seen that. Hmmm, is your gear indicator working?
91ss is offline
post #3 of 9 (permalink) Old 03-21-2014, 08:48 PM
It is probably part of the connector for the turn signal switch. It is supposed to clip onto the side of the steering column.
Fred Kiehl is online now
post #4 of 9 (permalink) Old 03-21-2014, 09:20 PM Thread Starter
No problems with the gearshift or turn signal.
But I am having ignition switch issues, which is why I wondered about that specifically.
post #5 of 9 (permalink) Old 06-01-2014, 12:07 PM Thread Starter
I'm putting the column back up after replacing the ignition switch.
If anyone can clue me in as to how this part gets installed I'd sure appreciate it.
I've seen it in the FSM but the diagram isn't very useful on where it actually goes.
A picture would be worth a thousand words...
post #6 of 9 (permalink) Old 06-01-2014, 01:39 PM
I looked through the FSM, and could not find the part. I believe it goes to the connector (95 in the FSM) for the turn signal switch on the side of the column, as a safety catch. I am not sure how it is oriented. I do not have a picture, but will try to remember to take one when I have a bare column available.
post #7 of 9 (permalink) Old 06-01-2014, 01:41 PM
Mr pogo's Avatar
Originally Posted by JackFish View Post
that looks like an electrical connector locking clip, it inserts into the appropriate connector from either front or back to lock the terminals in place.
each leg slides into a terminal hole and the clip locks into place.
Mr pogo is offline
post #8 of 9 (permalink) Old 06-01-2014, 02:21 PM Thread Starter
Aah, yes it does look connector-ish.
It's on page 3F5A-15, Figure 29, part 74, retainer, cable.
The solenoid has a cable, maybe on that?
post #9 of 9 (permalink) Old 06-01-2014, 03:33 PM Thread Starter
This view isn't much help...
