L05 to L03 swop parts - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 10-06-2001, 12:58 PM
BBODYLTZN
If i was to swop out my TBI with the whole computer from a L05 on to my L03 and a whole rear-end with a 3.42 from my 3.23 would i gain any performance and if so how would it affect my 1/4 mile.thanx
DAVID/92 CAPRICE LTZ
post #2 of 10 (permalink) Old 10-24-2001, 11:46 AM
BBODYLTZN
hello !!!!!!!!!! [img]1.gif[/img]
post #3 of 10 (permalink) Old 10-24-2001, 01:00 PM
RoadRunner9c1
I don't think your motor's starved for gas...might want to look farther if you want more power. And what the hell is "Durb" all about on your homepage.
post #4 of 10 (permalink) Old 10-24-2001, 09:16 PM
BBODYLTZN
"durb" thats for the ladies if you know what i mean [img]6.gif[/img] all jokes aside i have the chance to strip a 92 caprice with a l05 and i was just wondering if i can swop any parts from it to my l03 that i would gain any performance from .
post #5 of 10 (permalink) Old 10-25-2001, 02:40 AM
AdioSS
Switching up to a 3.42 gear won't help much at all when you've already got 3.23 gears. And the L05 Computer stuff will work with your L03, but you are probably better off leaving it alone.
What you could do is sell parts off that car, like, to me I could use a 3.42 rear (I've got 2.56 gears now!) an L05 Computer, the L05 TBI, and the Y-pipe However, I don't have the funds fo it
post #6 of 10 (permalink) Old 10-25-2001, 05:29 PM
sar_moby
Hi-( is this a stock LO5 or a 9C1LO5?)
My recommendation would be to pull out the following;
1. injectors(9C1 has higher #/hr. injectors than stock LO5)
2. TBI for parts( other than injectors , they are the same thing)
3. Computer chip( ECM should be the same unless a 9C1(?)).
4. airbox( keep a stock one for later)
5. If it is a 92' the Y-pipe is the same as civi/stock( I am pretty sure)
6. silicone hoses?
My .02Cents- Scott
post #7 of 10 (permalink) Old 10-25-2001, 05:55 PM
BBODYLTZN
its a 92 9c1 im getting for the front clip but i can strip it for what ever i want i was thinkin of what i can use from the l05 that i would benifit for my l03.the engine is locked so im not gonna use it . [img]7.gif[/img]
post #8 of 10 (permalink) Old 10-26-2001, 10:25 AM
sar_moby
1.It would be worthwhile to pull out the oil and power steering cooler if so equipped.( if you have headers the oil cooler may not work( you could sell it if that is the case)
2. check on the Y-pipe( it should be 3" unlike your stock one) I don't think it is on the 92' though.
3. Check on the trans for the 1st gear lock out bracket( u might want it)
4. check the alternator( 140 vs 100 amp)?
5. How many miles on the car?
( HD springs on 9C1's ?)
6. This is a stretch( camshaft on 9C1 was more aggressive( will it fit a 305?)
If the price is right, the upgrades may be worth your time.
- Scott
post #9 of 10 (permalink) Old 10-26-2001, 02:08 PM
Blues77
It couldnt hurt swappin the rear... do you have a open rearend? If the other is posi get it. Pulling the engine wouldnt be a bad idea, if the block is still there, it could be a fun rebuild. If you could get the front bumper off Ill give you some $ for it...I live in Chicago area also. [email protected]
post #10 of 10 (permalink) Old 10-26-2001, 06:53 PM
BBODYLTZN
I need the whole front clip cause of an accedent .The donor car has almost 300k on it and the engine has locked up.I'm taking everything from the fenders to the bumper including the hood for my car until i get my cowl hood i need the rear-end because mine is making a bad grinding noise so i might as well take that to plus it has a 3.42 in it so thats a plus.I dont need any of the interior parts but i'm going to strip it anyways and dye it black and use my original interior as a back up . I was realy looking for a 94-96 caprice and was going to do a chassis swop but i dont feel like messing with all the wiring since my caprice is the top of the line model i dont wanna mess with all the extra bells and whistles. [img]6.gif[/img] . If you guys have anymore suggestions i would like to hear them.
Thanx for the help/David-Chicago [img]6.gif[/img]
