Real Quick. 1996 Caprice VIN # for LT-1 - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 01-31-2003, 01:54 PM
Sweet 82
What letter in the VIN indidcates whether it is a L-99 or an LT-1.
post #2 of 10 (permalink) Old 01-31-2003, 02:08 PM
96CapriceDCM
5th I belive....should be W = L99 or P = LT1
post #3 of 10 (permalink) Old 01-31-2003, 06:34 PM
Sweet 82
Well... I got the VIN#-1G1BL52W2TR174997. The 8th digit is a W. I don't see an P's. So, stay away from it them. I would be going from my Roadmaster, which is pretty quick. What is the ratings for a L-99? How dissapointed would I be(performance wise)? Also, does anyone have a current CARFAX account where they could run the number for me? I've only seen a picture of it in the new Auto Mart. 81,000 miles, Beige w/matching leather, alm. wheels, white walls, all power equipment, etc.. Looks like an old man's car. They advertise it at $136.84/month w/ no money down.
post #4 of 10 (permalink) Old 01-31-2003, 07:31 PM
andrew9C1
You're right; the 8th digit is P for LT1. I'd sure stay away from it!
post #5 of 10 (permalink) Old 02-03-2003, 07:41 AM
'94XTHP
VIN: 1G1BL52W2TR174997
VEHICLE INFORMATION
Warranty Start Date: 02/25/1997
Delivering Dealer : DEVEREAUX MOTOR SALES, INC.
230 BUFFALO ST
FREEPORT, PA 16229-1330
(724) 295-2171
CAMPAIGN ELIGIBILITY
Vehicle Has No Current Record Of Outstanding Campaigns.
CLAIM HISTORY
03/15/2000 048411 # B7476 - LEFT SIDE FENDER MOLDING R&R OR REPLACE 36705 miles
02/24/2000 048027 # J9995 - CUST COMPLAINT NOT DUPLICATED - ENG. EM1SSION 35917 miles
10/13/1999 045511 # J5590 - PUMP, FUEL(ENGINE MOUNTED) - R&R OR REPLACE 32665 miles
10/13/1999 045511 # T2020 - WARRANTY TOWING 32665 miles
10/13/1999 045511 # Z7901 - 1-DAY COURTESY TRANSPORTATION 32665 miles
03/30/1999 041366 # J0200 - INTAKE GASKET RPL 27560 miles
03/30/1999 041366 # Z7901 - 1-DAY COURTESY TRANSPORTATION 27560 miles
11/24/1998 039128 # E7960 - STEER IDLER ARM RPL 25016 miles
05/28/1998 035699 # H0127 - ROTOR ASSEMBLY - R&R OR REPLACE/BOTH 18419 miles
07/02/1997 029645 # D1440 - RT AIR DEFLECTR RPL 5356 miles
06/27/1997 029511 # N6360 - INSTRUMENT PANEL RP 5033 miles
05/13/1997 028557 # N2145 - L/F DR WIN SWCH RPL 2894 miles
05/13/1997 028557 # C9995 - BODY INTERIOR - SYMPTOM DIAGNOSIS 2894 miles
03/14/1997 027459 # F2003 - RR DIFFER GSKT RPL 764 miles
09/27/1996 N19324 I Z7000 - NEW VEHICLE INSPECTION ALLOWANCE 13 miles
VEHICLE BUILD
Merchandising Model: 1BL19 - 1996 CAPRICE CLASSIC SEDAN
Gross Vehicle Weight Rating: 2362 kg (5208 lb) Order Number: 071AUW
Build Date: 09/18/1996 Build Plant: 1TRB - ARLINGTON ASSEMBLY PLANT
OPTION CODES
AA7 AG1 - DRIVER 6WAY POWER
AG2 - ADJUSTER, 6-WAY POWER SEAT, AK5 - SEAT, INFLATABLE, DRIVER & PASS
AM6 - SEAT - 60/40 SPLIT FRONT BENCH AP9 - CONVENIENCE
ARL - ARLINGTON, TX, USA AU0 - REMOTE ENTRY
A23 - HEAT REFLECTIVE A90 - LID, REM CONT ELEC RELEASE
B18 - INTR, DELUXE C4A - SAVER 1
C49 - RR WINDOW, ELECTRIC C60 - AIR CONDITIONER FRT, MAN CONTRO
C71 - INTR, FRT DR, COURTESY C96 - INTR, QTR, COURTESY & SINGLE RE
DD2 - SUNSHADE, COVERED DE5 - DR/PASS PWR HTD FOLDING
DF6 - TILT, AUTO, DUAL READING LAMPS DL5 - ROADSIDE SERVICE INFORMATION
D64 - RH, SUNSHADE, ILLUM FE1 - SOFT RIDE
FE9 - FEDERAL EMISSIONS GU5 - 3.23 REAR AXLE RATIO
G80 - LIMITED SLIP IQ2 - INTERIOR DESIGN (Q2)
JA1 - LIGHT WEIGHT, DISC/DRUM JM4 - ANTI-LOCK BRAKE SYSTEM
KC4 - ENG OIL KG9 - 140 AMP
K34 - CRUISE CONTROL L99 - 4.3 LITRE V8 MFI
MX0 - 4-SPEED AUTOMATIC TRANSMISSION M30 - 4L60 AUTO TRANS
NF2 - EMISSION SYSTEM, FEDERAL TIER 1 NG5 - EMISSION, CERTIFICATION, FIFTY
N30 - DELUXE N40 - POWER, NON-VARIABLE RATIO
N81 - FULL SIZE PA5 - SPORT/DELUX WHEEL COVER
PB4 - WHEEL PD4 - 15 X 7, ALUMINUM, 5 SPOKES (LMA
QCV R7A - SALES ITEM NO. 26
T82 - AUTOMATIC ON-OFF T87 - CORNERING
UN0 - AM/FM STEREO, SEEK/SCAN, CD, AU UQ1 - PROVISIONS, AM/FM STEREO
UQ5 - 4, DUAL FRT DR MTD, DUAL EXTD R U02 - INSTRUMENT CLUSTER
U75 - POWER ANTENNA VK3 - FRT MOUNTING PKG
VM3 - CONSUMER, CONTAINS BPR IMP STAN V03 - EXTRA CAPACITY
V73 - USA/CANADA 1AY - STOCK
1SC - UPFITTER EQUIP. GROUP - 1SC ** 33Q - LT DRIFTWOOD MET (91)
33U - EXTERIOR, LT DRIFTWOOD MET (95) 6TD - COMPUTER SEL SUSP (6TD)
64I - LT BEIGE (I) (96) 642 - LEATHER, LT BEIGE (2) (96)
7TF - COMPUTER SEL SUSP (7TF) 8RZ - COMPUTER SEL SUSP (8RZ)
9RZ - COMPUTER SEL SUSP (9RZ)
post #6 of 10 (permalink) Old 02-03-2003, 08:23 AM
Sweet 82
WOW! Hey, thank you VERY much VIN Guy. Could you please do me one favor? Could you run my VIN because I know that it's been repaired before but the report I got (I think it was CARFAX) was VERY vague and didn't even mention anything about a wreck. All it did was told me that it's a good title. The VIN is 1G4BT52P8SR421062. Thank you again.
post #7 of 10 (permalink) Old 02-03-2003, 09:36 AM
'94XTHP
My report doesn't show anything either, but that's how it usually goes:
VIN: 1G4BT52P8SR421062
VEHICLE INFORMATION
Merchandising Model: 4BT69 - 1995 ROADMASTER LIMITED SEDAN Warranty Start Date: 04/23/1995
Delivering Dealer : JOHN NARETTO BUICK, INC.
PO BOX 86
WHITE OAK, PA 15135-0086
(412) 664-9100
95071 STEERING COLUMN TRANSMISSION SHIFT CONTROL ADJUSTMENT N/A Closed
96010 LOWER CONTROL ARM BALL JOINT N/A Closed
CLAIM HISTORY
02/29/2000 206820 # J0500 - RT HEAD GASKET RPL 63124 miles
10/26/1998 169363 # E9050 - POW STEER PUMP RPL 47370 miles
10/10/1997 077189 # B7521 - LT W/S PILL MLD RPL 36168 miles
01/24/1997 125316 # E8622 - POW STEER HOSE RPL 25231 miles
11/08/1996 065900 # C0383 - L/R WIN REG R&R/RPL 23146 miles
07/09/1996 061382 # J3250 - RAD COOL SURGE RPL 17410 miles
05/17/1996 059504 J V9865 - 96C14 LOWER CNTRL ARM BALL JOINT-INSPECT 17110 miles
05/17/1996 059504 # N3615 - BLADE WIPER RPL 17110 miles
02/27/1996 042436 # D3052 - SEAL EVAP TO COMP 14134 miles
02/27/1996 042436 # D1705 - MAIN HARN R&R/RPL 14134 miles
01/25/1996 055364 # N0225 - HEADLAMP AIM 13077 miles
12/21/1995 104202 J V9800 - 95C61B-CAR STEERING COLUMN TRANS SHIFT CONTROL ADJUST 11299 miles
11/29/1995 103216 # N0441 - LT COM HDLAM BLB RP 10597 miles
10/20/1995 052212 # E7680 - STEER COLUMN - REPLACE 9580 miles
VEHICLE BUILD
Gross Vehicle Weight Rating: 2431 kg (5360 lb) Order Number: 59094F
Build Date: 03/24/1995 Build Plant: 1SRB - ARLINGTON ASSEMBLY PLANT
OPTION CODES
AG2 AG3 - 6WAY P/SEAT W/MEMORY
AK5 - SEAT, INFLATABLE, DRIVER & PASS AM5 - SPLIT 6WAY ADJUST
AU4 - SIDE DR, ELEC, AUTOMATIC A91 - ELECTRIC TRUNK PULL DWN
BY1 - EXTR, EMBLEM, BODY, VAR 3 C68 - ELECT AIR CONDITIONING
C90 - INTR, FRT & RR DRS, COURTESY C93 - OPERA
DE5 - DR/PASS PWR HTD FOLDING DF6 - TILT, AUTO, DUAL READING LAMPS
DL5 - ROADSIDE SERVICE INFORMATION D64 - RH, SUNSHADE, ILLUM
D74 - LH, SUNSHADE, ILLUM D84 - TWO TONE PAINT
FE1 - SOFT RIDE FE9 - FEDERAL EMISSIONS
GM8 - 2.56 RATIO IDC - INTERIOR DESIGN (DC)
JA2 - POWER BRAKES JM4 - ANTI-LOCK BRAKE SYSTEM
KA1 - SEAT, FRT KD1 - TRANS, OIL
KG9 - 140 AMP LT1 - GAS, 8 CYL, 5.7L, MFI, HO
NA5 - EMISSION SYSTEM, FEDERAL TIER 0 NK4 - SPORT LEATHER
NV7 - POWER STEERING VARIABLE N10 - DUAL/SPORTY EXHAUST
N81 - FULL SIZE PA3 - ALUMINUM WHEELS
PA5 - SPORT/DELUX WHEEL COVER QUK
UH7 - INSTRUMENT CLUSTER UL0 - RADIO 2001-AM/FM, CASS
UQ1 - PROVISIONS, AM/FM STEREO UQ3 - PREMIUM SPEAKER SYSTEM INCLUDES
U75 - POWER ANTENNA VM3 - CONSUMER, CONTAINS BPR IMP STAN
V73 - USA/CANADA Z22 - BUICK ROADMASTER ITT LMTD
1SE - UPFITTER EQUIP. GROUP 1SZ - OPTION PACKAGE
14C - DARK PEWTER CLOTH 14I - VERY DK GRAY (I) (97)
87L - EXTERIOR, GUNMETAL MET (91) 91U - PEARL PAINT
post #8 of 10 (permalink) Old 02-03-2003, 02:11 PM
SSWEET
Paging Mr. Vin Guy Can you do me a favour and run my vin? VIN#1G1BL52P3TR149745
Thanks.
post #9 of 10 (permalink) Old 02-03-2003, 02:14 PM
phil_from_france
Hi VIN guy,
fantastic job about VIN !! I don't want to know your secret but would you decipher my "new" '96 Rdm i just bought and which is now on the boat between US and France. I've tried carfax but haven't found all the facts you must have..
VIN: 1G4BR82PXTR414423
Please email me privatly
Thanks,
post #10 of 10 (permalink) Old 02-04-2003, 01:20 PM
Sweet 82
Thank you VIN guy!
