Cruise Conrol Module...where to get one? - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 12-12-2002, 04:06 PM
jpalmer
Unhappy
Hi guys,
Looks like my cruz contrl is shot and Uncle GM wants 375 big ones for a new module. I've tried the auto parts store and they say it's a dealer item. You guys know any place else that might carry one...other than the wrecking yards?
Thanks,
JP
post #2 of 6 (permalink) Old 12-12-2002, 07:38 PM
rancorkeeper
You're gonna have to go to a dealership, junk yard or call Dal or Chris McCabe. Parts warehouses & auto stores just don't carry things like computers, ABS modules or cruise control boxes. You should be able to find one reasonably priced at a salvage yard as several different GM models will have one you can use. Good luck.
post #3 of 6 (permalink) Old 12-14-2002, 04:04 PM
maxwellc
Are you sure it's the module? I thought mine was screwed to but I remembered something I read on here. Check to make sure your center high mount stoplight isn't burnt out. If it is, replace the bulb and the cruise will work. If that ain't the prob, sorry, I can't help. I was so happy when I fixed mine that way that I always point that out to others on here when they have cruise probs. Nothing like fixing the cruise for $.63!
Sean
post #4 of 6 (permalink) Old 12-15-2002, 01:23 PM
chevmdnss
Where is the cruise module located on a 94-96? I found a wrecked Roadmaster in a salvage yard, and am going back Monday 12/16 to see what I can get off it.
post #5 of 6 (permalink) Old 12-15-2002, 01:51 PM
96capriceMGR
Drivers side inner fender, in front of the brake booster.
post #6 of 6 (permalink) Old 12-19-2002, 02:49 PM
jpalmer
Thanks for the input guys. My brake light does work the prob with the cruz is that it works for awhile and then slowly loses speed. If I reset it it starts working again for a little bit. This hapened to me before and I let GM fix it, trouble is the module is only gauranteed for 12 months. Sounds like a racket to me. Oh well off to the wrecking yards.
JP
