transmission code?- re:VSS replacement - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 01-07-2006, 02:19 AM
Daz
Im trying to get a VSS for my 91 Caprice but the part stores said that there are three kinds.Theyre asking me for a transmission code.I have the part off but the numbers on the part doesnt give them anything.Im trying to avoid buying one from GM which is 4 times the price
post #2 of 9 (permalink) Old 01-07-2006, 08:20 AM
cletus284
Tranny for all '91's is the 700R4. What kind of code are they looking for?
post #3 of 9 (permalink) Old 01-07-2006, 08:33 AM
Daz
THey said its stamped on the case..
I know its a 700R4/4L60 too.
All I know is that there are two kinds..and the other is for the 4L60E
post #4 of 9 (permalink) Old 01-07-2006, 08:51 AM
cletus284
The 4L60E was not used on the B-Body line until the LT1 and L99 were introduced in '94. I don't think the 4L60E was even in production in 1991. That should solve your problem right there.
post #5 of 9 (permalink) Old 01-07-2006, 10:28 AM
Daz
You are no help
Either way for the others,
The VSS code that they are looking for depends on the RPO number..DN8,DNF or DNE.There's at least 3 kinds of VSS for 91-93
post #6 of 9 (permalink) Old 01-07-2006, 11:00 AM
cletus284
Ah, OK, now I'm awake and I understand. I looked at a GM RPO list and the different VSS RPO's are either D8_ (where _ = a letter A through N) or D9_ (where _ = a letter A through E). That should be listed on the SPID label on the trunk lid. Makes sense that there would be 3 of them, as you'd need a different one for each axle ratio (Duh!).
post #7 of 9 (permalink) Old 01-23-2006, 08:21 PM
MR.ED
The vss should be the same no matter of ratio.. Its the reluctor that changes with the ratio. Weird that they have so many!
post #8 of 9 (permalink) Old 01-23-2006, 08:25 PM
MR.ED
Actually on second thought the reluctor should be the same too. The program changes the speedo output not the vss input. are the 3 vss's different sizes or something?
post #9 of 9 (permalink) Old 01-24-2006, 07:37 PM
dedsqwirl
The 4L60 is a 700R4. The 4L60e is electronically controlled for all gears. The 4L60/700R4 has an electronic overdrive. It will shift without the computer but won't go into overdrive.
For the 3 different numbers, get the GM number and go to gmpartsdirect and see what their price is. Or take the number to the parts store and have them cross it over to who ever makes their parts. (They will have to look in a book to do this.) If the parts book have pictures you can look at those too.
I had a replaced a 94 with a 96 roadmaster transmission and the tailshafts were different. The 94 sensor was cracked/leaking. The 94 sensor was huge compared to the 96. I cut off the pigtail and used a pigtail for a temp sensor.
I hope this information is helpful.
