Posi, or no Posi in our 91-93 Caprices? - Chevy Impala SS Forum
post #1 of 18 (permalink) Old 11-05-2000, 03:08 AM
Chris 94Z A4
I have a '92 Caprice Classic and I was wondering if any of you might know.
Thanks,
Chris
post #2 of 18 (permalink) Old 11-05-2000, 07:15 AM
Fletch
It was optional. You can check your option codes or you can jack up your car so that both rear wheels are off the ground. Then turn one wheel by hand, if it turns by itself you do not have posi, if the other wheel turns in the opposite direction you do have posi.
Fletch
post #3 of 18 (permalink) Old 11-05-2000, 11:09 AM
Dimo's 95 9c1
Isnt it if the other wheel turns in the opposite direction you dont have posi?
Dimitri
First base delete PVC pipe intake, drilled air box
post #4 of 18 (permalink) Old 11-05-2000, 12:12 PM
White Smoke
I have a 95 9C1 that lacks the G80 option code. What exactly does a positraction rear end do, and why is it so desirable? Would it be worth the money to shell out the cash and buy an Auburn posi (I hear thats what GM used for OEM).
post #5 of 18 (permalink) Old 11-05-2000, 01:31 PM
tirpitz
Another way to see if you have posi is to do a good burnout and see if you left 2 nice patches(posi) or one patch(non-posi)
Eric Maxwell
96 MySStic
SOCALSS
Bcoddington Daytona's 17x10 Rear, 17x8 Front; SSRI; hodgepodge catback exaust; Billet stuff on dash and pedals.
www.geocities.com/tirpitz_2000.html
www.members.home.net/turpitz2000/
[email protected]
post #6 of 18 (permalink) Old 11-05-2000, 01:50 PM
Fletch
tirpitz,
I like your way better.
Fletch
post #7 of 18 (permalink) Old 11-05-2000, 02:35 PM
Mike454SS
tirpitz's way is definitely the best and most accurate way to determine if you have posi, however, the other ways are look for the G80 which means you have posi, or you can block both front wheels, put the car in neutral with the engine off, don't set the parking brake, jack up the rear of the car by placing a sturdy strong jack under the differnetial (center it on there well). now go to either rear wheel, and turn it, the other rear wheel shoud turn in the same direction, if it does, you have posi, if it turns in the opposite direction or doesn't turn at all you dont have posi.
what posi does is sorat like the all wheel drive commercials you see, it transfers power form the wheel that slips to the wheel that grips, and if neither wheel is gripping then they both wind up getting equal power. It does have some margin of slippage included though (limited slip not no slip) becasue when you turn your car while its moving, the wheel on the inside of the turn moves slower and slower than the wheel on the outside, the degree of difference in rotational speeds is directly proportional to the tightness of the turn. People who dont do burnouts or drag race will never really need posi unless you live in an area with snow or rain and your tires wind up slipping. Drag racers like posi because they can essentially get twice the power to the rear axle when launching their car before losing traction. in the snow, you always see car stuck with one wheel spinning and the other wheel just kind of sitting there, and usually its the one on pavement, the spinning one is in the snow, posi will take the power away from the spinning wheel and give it to the other one. its the same in the rain. for those who do not drag race or to burnouts, posi makes it just a little harder to get the car stuck in bad weather, and for those who drag race, they can launch harder, and burnouts look cooler when both wheels are smoking and 2 patches of rubber are being left behind on the ground.
post #8 of 18 (permalink) Old 11-05-2000, 02:37 PM
Chris 94Z A4
What I was looking for is an option code for the posi and gear ratio.
Thanks,
Chris
post #9 of 18 (permalink) Old 11-05-2000, 06:06 PM
Dimo's 95 9c1
G80 is the code for GM cars
One question:
If you have limited slip posi then do you still leave two strips of rubber?
Dimitri
post #10 of 18 (permalink) Old 11-05-2000, 09:02 PM
White Smoke
and what about for AutoXers? I really enjoy doing that. Would a posi rear end really help me out there? It seems like keeping more traction in ultra tight turns could be a good thing and a bad thing. If so its beginning to sound like my next mod...
