engine swap - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 11-15-2005, 04:35 PM
mike c p
I am new to the post and maybe this has been covered before. I have a 94 caprice with a 4.6? 305 I presume. I also have a 94 caprice cop car. I would like to put the 350 into to caprice with the 305. What do I have to swap with the change;computer, electrical, etc. Thanks
post #2 of 7 (permalink) Old 11-15-2005, 04:44 PM
chevmdnss
Yes it has been covered.........
you have a 4.3l (what is known here as L99) which is a 265 cid, as long as you have 94 and up cars, then the swap is not that difficult.
The "350" car is an LT1 IF it is 94-96
Yes swap the motor and ECM
Do a search, and you will find more info on this.
post #3 of 7 (permalink) Old 11-15-2005, 05:48 PM
VIN Guy's Alter Ego
Do a LOT of reading before you ever turn the first bolt. [img]graemlins/5.gif[/img]
You can use the same PCM (computer), but it has to be reprogrammed.
post #4 of 7 (permalink) Old 11-15-2005, 05:54 PM
signguy
Next thing ya know someone will try putting an LT1 in a Jag...................... [img]tongue.gif[/img]
post #5 of 7 (permalink) Old 11-15-2005, 05:58 PM
VIN Guy's Alter Ego
Some morons will try almost anything... [img]graemlins/.gif[/img]
post #6 of 7 (permalink) Old 11-15-2005, 06:16 PM
chevmdnss
Why would he use the same PCM, if he has a good LT1 PCM??
post #7 of 7 (permalink) Old 11-15-2005, 06:20 PM
96capriceMGR
see my sig
Frankly though seeing as you got the displacement in litres and cubic inches wrong I am guessing a motor swap is beyond your immediate abilities.
