Help with water leak! - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 11-13-2001, 09:11 PM
koolwhipman
I have my 96s carpet out because my floor was wet on both front sides and on passenger rear. There is a little rust so I know its been moist for a while. It rained a little taday and the water appeared on the passenger front and back. Anyone ever have this problem? Any possible leak places? I'm thinking firewall/cowl...
post #2 of 2 (permalink) Old 11-16-2001, 08:17 AM
Mattia-SS
Red face
I know what your are talking about. I had all those leaks too.
First of all the window frame wasnt tight. Had to remove the window and tighten.
Second I removed the metal under the windshield (under wipers) There´s a compartment wich got filled with alot of water pouring down the windshield when it was raining. Used plain silicone.
Third: The rear rubberlist around the doors-the water "climbed" over them! I removed those too and filled under with silicone.
This should solve at least one of your leaks I hope.
