True dual exhaust systems for 91-93 305's??? - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 10-07-2000, 10:54 PM
Chris 94Z A4
Anybody ever done this? What systems are out there? Can I use a Dynomax cat-back from the Impala SS?
Thanks,
Chris
post #2 of 9 (permalink) Old 10-08-2000, 09:45 AM
patgizz
think you need a 94-up crossmember with 2 humps, the 91-93 ones dont have that.
post #3 of 9 (permalink) Old 10-10-2000, 09:38 PM
CAPRICE9C1SS
Smile
pat, u r right.. 24 bucks from GM also you need a special tranny tail shaft to fit that crossmember...you also need to weld 2 inches of steel onto your frame to bolt the cross member up... the tranny shaft is factory 4l60.. 94-96 trannys. the tail shaft from gm is over 100 bucks...good luck finding one at a wrecking yard.
Steve S.
93 9C1
88 9C1
post #4 of 9 (permalink) Old 10-11-2000, 07:54 PM
patgizz
screw that ill use the double hump x member from my 71 - same width +/- 1/2", and i have a torch, drill, and welder. i can make it fit!
post #5 of 9 (permalink) Old 10-27-2000, 12:31 PM
GhoSSt
Unhappy
<BLOCKQUOTE>quote:</font><HR>Originally posted by CAPRICE9C1SS:
. . . also you need a special tranny tail shaft to fit that crossmember... the tranny shaft is factory 4l60.. 94-96 trannys. the tail shaft from gm is over 100 bucks...
<HR></BLOCKQUOTE>
Why would you change the tailshaft on a 700R4/4L60 to a 4L60E tailshaft? They should be the same. Or do you mean tail shaft housing? Please clarify.
PS: Check out
http://home1.gte.net/res05gmd/caprice/faq.htm##6 Dual Exhaust
For info on how to REALLY do it clean. . .
Kelly 'GhoSSt' Rosato
[This message has been edited by GhoSSt (edited October 27, 2000).]
post #6 of 9 (permalink) Old 10-31-2000, 10:04 AM
CAPRICE9C1SS
Red face
yes, ghost, my bad..the TAIL SHAFT housing will need replaced to fit the 94-96 crossmember. Sorry for the confusion
Steve S.
93 9C1
88 9C1
post #7 of 9 (permalink) Old 11-01-2000, 12:12 PM
GhoSSt
So why did you feel it (the tailshaft housing) needed to be replaced? I think the tranny mount is the same, please feel free to elaborate. (Enquiring minds wanna know. )
1996 Impala SS, 383 LT4 (14.65 up here, 13.24 lower)
1984 Firebird, +.060 350 (Vortech Heads, HOT Cam, and schtuff)
1993 Caprice, 5.7 TBI (stock . . . FOR NOW)
"And if you wrong us, shall we not revenge? Revenge. The villany you
teach me, I will execute, and it shall go hard but I will better the
instruction."
Shylock in Act III, Scene I of 'Merchant of Venice' by William Shakespeare
post #8 of 9 (permalink) Old 11-02-2000, 09:35 AM
CAPRICE9C1SS
Smile
I have not done the mod myself yet. I have read MANY articals on this subject. Also I purchased a 94-96 crossmember and it would not fit the transmission or the frame. So thats why I said you need a diffrent tail shaft housing. Some articals I read say that you can modify the housing.
Steve S.
93 9C1
88 9C1
post #9 of 9 (permalink) Old 11-02-2000, 04:59 PM
GhoSSt
<HR></BLOCKQUOTE>
I know that you have to add about 2 inches of flat iron to get teh crossmember (94 - 96 dual hump) to mount, but this is a first on modifying the tailshaft housing or tranny mount problems. Can you post some of the articles on this issues that you've read, I'd like the info myself.
instruction."
