Radiator - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 11-19-2005, 09:22 PM
marion
Prior to retiring my 91 to the garage I over heated my motor several times on purpose cause I knew I was rebuilding the car should I replace the radiator with my rebuild?
post #2 of 5 (permalink) Old 11-27-2005, 06:13 PM
marion
Good job guy's
post #3 of 5 (permalink) Old 11-27-2005, 07:53 PM
mr k gee
I would say yes, I mean if you are rebuilding the car...whats another couple hundred dollars for a nice new radiator?
post #4 of 5 (permalink) Old 11-28-2005, 06:24 AM
marion
Thankyou K Gee this was all I needed to know
post #5 of 5 (permalink) Old 11-28-2005, 07:08 PM
coleman
No need to replace the radiator unless it has permanent chunks of scale and rust in it, or it has a leak.
If you're going to upgrade to a better radiator than stock, that's the only time you need to worry about replacing a perfectly good stock unit.
