passanger side spotlight - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 02-01-2006, 09:40 AM
94Rudemaster
Is the spot light the universal for both sides or they just one fliped up side down?
post #2 of 4 (permalink) Old 02-01-2006, 10:33 AM
95 9c1 Lt1
the moutning bracket is different
I would imagine the actual spotlight is the same. (perhaps they had the toggle switch operating oposite but who knows)
post #3 of 4 (permalink) Old 02-01-2006, 04:48 PM
DPS 9C1
I have a set of the OEM lights, L & R. I'm in the process of mounting the pass. side light, my car didn't have one originally. I can see no difference between the spotlights. Even the switches turn the same way. And as mentioned above, the mounting brackets are different.
James
post #4 of 4 (permalink) Old 02-02-2006, 05:59 AM
94Rudemaster
Since your cuting im planing on puting a set on a roadmaster to make it look like a 50`s hot rod look. How are you going about drilling and cutting the car? what size is the hole that goes through the pilar? So what your saying is that all I need to do is find the passanger side bracket and ill be set?
