LTZ?LT1? - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 02-25-2001, 07:58 PM
BBODYLTZN
If ltz doesnt stand for anything what does LT1 stand for just curious
92 CAPRICE LTZ stock 305,3.23gears,pete jackson gear drive,K&Nfilter,customduals,ssgrille,clear fronts and rear lights,msd 8.5 wires x4plugs 6Amsd box,B&M shift kit
DRIVE IT LIKE YOU STOLE IT
post #2 of 11 (permalink) Old 02-25-2001, 09:10 PM
El_Dude_2k
It's just a code that GM used for the engine. Just like yours is LO3, and the TBI 350 LO5, the MPFI 350 in the B-bodies, F-bodies, and Corvettes code was LT1.
post #3 of 11 (permalink) Old 02-25-2001, 09:34 PM
BBODYLTZN
Thumbs up
oh ok i see thanks
post #4 of 11 (permalink) Old 03-06-2001, 01:04 PM
Mike454SS
I don't know what LTZ stands for, but according to B-Body.net, LT1 stands for lima tango one, LT4 stands for lima tango four, and L99 stands for lima nine-nine. Now whatever lima means, I have no idea.
This http://www.b-body.net/acronymSS.html is a good page to look at if you want to know what some of the acronyms tossed around this forum mean, they don't have em all, but they do have a lot.
95 9C1 LT1
post #5 of 11 (permalink) Old 03-06-2001, 01:20 PM
Enigma
Actually Lima is simply a way of saying L. It is a way of annunciating. For instance, instead of saying N1A6P, It could be stated as November 1 Alpha 6 Papa.
(Can anyone tell I'm a Pilot )
Ben Bawkon
96 DCM - (4DR-LT1)
[email protected]
**Never Look Back; Those Flashing Red and Blue Lights will Drive you Crazy**
post #6 of 11 (permalink) Old 03-06-2001, 10:18 PM
El_Dude_2k
Here's a question to add to the confusion of the LTZ name: Does anyone know which engine the LTZ cars came with, because I have been getting conflicting info. I've seen 1991-1993 LTZ's that have the 350, but according to BBODYLTZN's signature, his has a 305, so who can clear this up?
1994 Caprice Classic 9C1
~White, spotlight, no mods yet.
1991 Caprice (civilian)
~Black, no mods yet.
ISSCA member #00320
post #7 of 11 (permalink) Old 03-07-2001, 12:22 AM
S.I. Super Sport
'91/'92 LTZ's only came with LO3 305's, '93 had a slightly detuned LO5 350 as an option.
Pete M. '96 DCM SS, '96 B4U Caprice, '91 9C1, '69 Impala spt cpe, '01 Yukon XL
post #8 of 11 (permalink) Old 03-07-2001, 10:24 AM
sar_moby
FYI the :LTZ is the "sport suspension package" that was available on the Caprice. I have a 93 w/ the detuned L05. It does have the 3.08 rear end w/ the GU4 positraction, F/R sway bars and higher rate front springs( possibly proportional rate)7TN, non-variable power assist steering,Al wheels, thick leather wrapped s/wheel,certified speedo, gas bib(white),short hood ornament(BA1) and the RPO code shows MD8 to be the THM 700R4 trans(?). From the post I have seen the frame is supposed to be the same as the 9C1. I have yet to find the following RPO codes that are on the car( IQC, UU8, U41, 1AY, 1SZ).
-Scott
post #9 of 11 (permalink) Old 03-07-2001, 12:17 PM
Sleeper
RPO MD8 is the 4L60.
The LTZ was a trim marketing package, like the LS is to a Caprice Classic. VIN denoted as a carline series. It is not a RPO.
Suspension should be F41 or FE3 for sport or firm ride/handling.
GU4 - 3.08
G80 - positraction
IQC - tires?
UU8 - radio,AM/FM stereo, SEEK/SCAN, AUTO REV MUSIC
U41 - indicator, low fuel
1AY - ???
1SZ - ???
??? = code doesn't come up in dealer network
For more RPO's http://www.9c1.com/technical/rpo_codes.htm
[This message has been edited by Sleeper (edited March 07, 2001).]
post #10 of 11 (permalink) Old 03-07-2001, 05:48 PM
sar_moby
Thanks Sleeper!
Still curious if all L05's for 93' have the 3" y-pipe and 9C1 manifolds. Car has a honeycomb type cat.(not the bead catalyst bed unit). I think the chip is different too. - Scott " I need more power cap'n"
