91 radiators? - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 09-27-2002, 10:47 AM
SSweet9C1
Hey will a radiator from an 87 boxy 9C1 with a350, fit a 91 9C1??
thanks! (this is for a possible winter beater)
jonathan
post #2 of 5 (permalink) Old 09-27-2002, 07:00 PM
SSweet9C1
i checked online on parts america online and came up with 3 different radiators for the 91 with an LO5, and one # for the 4bbl 370 out of an 87....
does this mean (for sure) that they are different, if so how different? or would it just be in a different box??
Someone out there must have a boxy and an early 90's 9C1!!!
TIA
jonathan
post #3 of 5 (permalink) Old 09-27-2002, 07:01 PM
SSweet9C1
err that is 4bbl 350 out of an 87..
post #4 of 5 (permalink) Old 09-28-2002, 12:09 AM
matthiasi
They will fit, with a teeny weeny little bit of work.
I put a '70 4 core (extra thick) in my old wagon. It's not quite as wide as my original 91 and doesn't have the oil cooler. I had to drill a bigger drain hole in the cross brace and trim the shroud. Otherwise, it fits perfectly and you couldn't tell it wasn't stock. I now run 165 all day long, unless I'm towing. In either case, it's
way too cool!
Matt
post #5 of 5 (permalink) Old 11-30-2002, 05:23 AM
brick b-body
Lightbulb
The space for a radiator is the same in the square B-Bodies as is it in the round B-Bodies. So yes, the '87 radiator will fit in the '91 car.
But the '91 radiator, stock for stock is a better piece. The radiators used in the round B-Bodies have a larger frontal area than the ones found in a sqaure B-Body. This is due to the much smaller grill area of the round B-Bodies compared to the square B-Bodies.
For a winter beater these differences may not matter much though.
