ABS quit working + idiot light - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 11-25-2000, 09:22 AM
patgizz
my abs always worked on and off, but now its totally quit and the light has come on. is there any way to check which component has failed?
1991 Dark Grey Metallic Caprice 305. Breathless air filter, chrome valve covers, SS grille, 15x8 rims with 245/60/15 BFG TA's Vara-Jection, 9C1 springs, III Hitch, Sony CD, accel 8mm wires and plugs, muffler eliminated, Pacesetter monza resonator tip, "baby system" 8" sub and 200W amp
Doesn't play well with others
My Homepage/Car Pics
Other Cars:
1980 Camaro
1954 Belair
1971 caprice for sale
1983 olds wagon for sale
post #2 of 6 (permalink) Old 11-25-2000, 06:17 PM
MUSSCLE in Milwaukee
Talking
Hello,
I repaired the ABS in my 93 Wagon right after I purchased it used.
I have the factory manual.Please email for more info or a fax copy of a few pages.
Here goes. The ABS computer is like the ECM . You connect terminal H in the DLC connector under the dash to ground . Terminal H is in the lower row, second from left. Turn the ignition to run. after 3 seconds the ABS Light will flash codes. Three codes 12's will flash. Then the trouble codes will flash. Then three more 12's will flash. Don't forget to remove the jumper.
Email me or post your codes.
Good luck.
Scott
'96 BBB SS - Tint, Pep Boys Intake with K&N, 160 Stat, Multiple Kill Switches, 14.84 @ 93 MPH.
93 DCM Caprice Classic Wagon - NO WOODGRAIN, Tint, AR 15" Rims, Multiple Kill Switches
86 Firebird - Black, No Winters, 305 Auto with Corvette Servo, Derale Oil Cooler, Exhaust Upgrades, 3.73 Posi, Peeling Clearcoat, Multiple Kill Switches
post #3 of 6 (permalink) Old 11-25-2000, 10:13 PM
patgizz
is that the diagnostic connector from the ECM or is there another one?
post #4 of 6 (permalink) Old 11-26-2000, 12:10 PM
CAPRICE9C1SS
I think he means the ALDL connector.
Steve S.
93 9C1
88 9C1
post #5 of 6 (permalink) Old 11-26-2000, 03:10 PM
Talking
The factory manual refers to the DLC. I would call it the ALDL also.
post #6 of 6 (permalink) Old 11-27-2000, 03:44 PM
patgizz
ok i just never heard the aldl called that before. ill try and do it wednesday.
