Should I shim a 1.5 herb Adams sway bar - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 09-08-2015, 10:03 PM Thread Starter
Cool Should I shim a 1.5 herb Adams sway bar
I currently have my rear factory swaybar shimmed
For drag racing. I am getting a used Herb Adams
Rear sway bar. Should I shim this one just like
My factory one or install it straight up without shims.
Keep in mind, this is only to help me launch at the track
On slicks. Currently I'm at low 1.7's on motor and
High 1.5's on a 75 shot. Tried the 125 shot and I ended
Up with low 1.6's . It spun and it didn't hook that well.
If anybody runs this bar or anything similar , can you let
Me know your experience and if you used washers to shim
It. Thanks.
Sleeperbuick is offline
post #2 of 5 (permalink) Old 09-09-2015, 07:02 AM
The Bolt-On Terror's Avatar
If you were happy with the shim thicknesses on your stock bar, I'd use half that on the HA bar as your starting point. Yes, definitely some shim is required for best starting line performance. The harder you hit the tires, the more bias (shimming) you need.
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #3 of 5 (permalink) Old 09-09-2015, 12:34 PM Thread Starter
Thanks a bunch. I figured that because the bar is a lot
Stiffer but just wanted to get another opinion.
Thanks .
post #4 of 5 (permalink) Old 09-09-2015, 02:01 PM
Send a message via AIM to FaSSt9602
How much shimming are you guys talking about? I'll be looking into this one I get mine back together...
1996 DGGM Impala SS
Project Resurrection 396 in the works!
FaSSt9602 is offline
post #5 of 5 (permalink) Old 09-11-2015, 08:45 AM
I did about 3/8" on each side with the stock bar. Do about half that with the HA bar.
Shim the rear bolt location on the driver side and the front bolt location on the pssgr side.
I suggest putting a jack under the frame on the pssgr side to give yourself a little slack in the system to get the washers in there.
