Napa Steering box - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 10-14-2015, 04:11 AM Thread Starter
pjslover's Avatar
Napa Steering box
I need a new steering box and like NAPA parts.
anyone know if this is the correct box for my 96 SS?
PS 391110
thanks
ORIGINAL OWNER
1st Base Sewer Pipe Mod,
Home Base Delete
"X" Pipe
Sequential Tail Lights
PMT Extended Upper and Lower Rear Control Arms
Stealth Brake, Metering Bolt Mod
Complete LED Interior, Including Radio
VATS Bypass
LED CHMSL
Camero 6 Speed EGR Valve
Moser Axles
Complete Front End replacement with MOOG parts
390,000 Miles and Counting
New Engine & Trans @ 304,550
Bilstein Shocks
Vogtland Springs
Hand Painted "IMPALA SS" Logo and Pinstripes
pjslover is offline
post #2 of 10 (permalink) Old 10-14-2015, 06:31 AM
RJI
That is the slow ratio Caprice box. The Impala box goes 2.75 lock to lock. Both will fit and work but the caprice box is about 3.5 turns lock to lock.
Please visit my website at: http://www.1finecaprice.com/
RJI is offline
post #3 of 10 (permalink) Old 10-14-2015, 07:32 AM Thread Starter
pjslover's Avatar
Any Idea where i can get the correct one?
ORIGINAL OWNER
Home Base Delete
"X" Pipe
VATS Bypass
LED CHMSL
Moser Axles
Bilstein Shocks
Vogtland Springs
pjslover is offline
post #4 of 10 (permalink) Old 10-14-2015, 08:10 AM
Try here:
http://www.powerperformancemotorspor...productId=1806
They are not cheap, but you get what you want.
I tried the link, and got a "page does not exist" screen.
post #5 of 10 (permalink) Old 10-14-2015, 08:24 AM
RJI
NAPA says it carries both the slow and quick ratio.
Part Number: NSP 88278113 is the quick ratio. The one thing to watch is that the rebuild is in fact a fast ratio box. When you pick it up count the turns full right to left. it should be 2.5 turns. Because they are interchangeable I have seen them put either in the box. Also make sure the box is centered before installing.
RJI is offline
post #6 of 10 (permalink) Old 10-14-2015, 09:47 AM
You also have to check the arc that the output shaft makes. The internal stops can be changed and appear to be the close ratio box, when in fact, the steering arc is compromised.
post #7 of 10 (permalink) Old 10-14-2015, 11:56 AM
RJI
Fred, I have never seen a re builder go through the trouble to change the gear to make it look like a fast ratio box, but I doubt the gears would mesh without binding. The stops are on the gears. You in theory could grind the stops of a fast ratio to make it look slow but the box would turn the wheels way too far. To me it's a non issue.
If you have done this please give me some hints. I have rebuilt boxes before but never heard of this actually being done.
RJI is offline
post #8 of 10 (permalink) Old 10-14-2015, 11:57 AM
can't speak from personal experience on the NAPA part, but I would suspect they are a very good alternative. It doesnt answer you question but when I installed my replacement box, I went to AdvanceAutoParts and ordered one from them. With the BIG35 Discount code I got it for less than $100 and have been happy with it.
Pretty sure the brand they carried at the time was Fenco, but now their site list something different. At the time they showed 2 units for a Caprice, 1 standard and the other for Police Vehicles (9C1) which was the quick ratio and the 1 I bought. But as others have said, be sure to check the amount of travel on the box to confirm what you got.
Also be aware that the Pitman Arm takes some serious Torque numbers. IIRC - it was in the 185 Ft. Pounds range and my Torque Wrench only went to 150.
post #9 of 10 (permalink) Old 10-18-2015, 12:56 PM
wytltng's Avatar
If I remember correctly, the regular caprice & the Impala had different pitman arm splines so they are not interchangeable.
wytltng is offline
post #10 of 10 (permalink) Old 10-18-2015, 05:12 PM
There are a couple of different Pittman arm lengths, but the splines are all the same. The box does not come with the arm, so it will have to be transferred to the new one.
