Automatic Level Control Tube Damaged - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 11-03-2015, 02:42 PM Thread Starter
While replacing my power steering hoses, I damaged the little tube at the left front wheel well that goes from the air compressor dryer to the back shocks. The GM manual shows a Tubing Repair Kit for the Electronic Level Control. Don't see anything about a kit on line. Any ideas from The B Body Brain Trust??
1996 Roadmaster Wagon; DGGM with Tan Leather.
Factory Stuff: Grand Touring Suspension, Towing Package and Heated Seats w/Driver Side Memory.
Deleted Stuff: Wood and Chrome Trim.
Added Stuff: Wilwood Front Calipers and Rear Discs, Z28 Gauges, Rear Sway Bar, Cadi flash to pass; 9C1 Front Springs; BBN Shorty Headers; Flashed PCM; SS Wheels w/Buick Centers; LED running lights; Clear Headlights; SS Trim Spears; Navi with BU Camera, Rain Sensing Wipers; GS and LT1 Trim; Sedan Rear Seats with Heat.
vagswagon is offline
post #2 of 4 (permalink) Old 11-03-2015, 03:24 PM
wytltng's Avatar
Go to a real parts store & get a air shock line kit. You can get either compression unions or something of the sort to mend it back together.
wytltng is offline
post #3 of 4 (permalink) Old 11-04-2015, 04:28 AM
Since the rest of that hose is 20 years old it would be wise to consider fishing a new one along/in the frame from comp to the rear.
FWIW I had the same line fail from a wearpoint, and a dealer used a teeny teeny compression union to make the repair. But that was 15 years ago when these cars were a lot nearer to current model.
post #4 of 4 (permalink) Old 11-04-2015, 11:20 AM Thread Starter
Thanks; I will follow both suggestions.
