If your bagged, need some advice - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 12-02-2015, 09:37 PM Thread Starter
In the near future I'll be bagging my SS. But for now I'm dropped on cut sprints but notice my bottom control arms are really close to the frame. Would like to know what you gus did to get more clearance or range of motion?
808SS is offline
post #2 of 5 (permalink) Old 12-03-2015, 09:03 AM
Open up the notch in the front and trim off the tabs that wrap around on the rear. Keep in mind the lever effect. Trimming X off near the pivot will increase travel at the wheel by Y*X amount.
threeimpalas is offline
post #3 of 5 (permalink) Old 12-03-2015, 07:03 PM Thread Starter
Any chance you have pics of notch?
808SS is offline
post #4 of 5 (permalink) Old 12-04-2015, 09:45 AM
You'll also need to be aware of where the tie-rod passes below the frame rail. It can also hit depending upon how low the car is, in which case, you'd need to notch and weld in a tube for clearance. It would be advisable to ensure the clamps on the tie-rod end connector are pointed down.
Just crawl under the car and take a look. It's pretty easy to spot.
post #5 of 5 (permalink) Old 12-04-2015, 07:41 PM Thread Starter
Mahalo for your help
808SS is offline
