lowerinf spring on 24 inch wheels? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 12-05-2015, 06:48 PM Thread Starter
lil754boy's Avatar
Anyone running lowering springs while running 24 inch wheels?
lil754boy is offline
post #2 of 4 (permalink) Old 12-06-2015, 12:25 AM
KW Baraka's Avatar
Tire diameter is a more important factor to fitment than wheel diameter....
What tire size are you looking to use?
KW
KW Baraka is offline
post #3 of 4 (permalink) Old 12-08-2015, 10:30 AM Thread Starter
lil754boy's Avatar
tire size
currently i am running 275 25 24
post #4 of 4 (permalink) Old 12-08-2015, 06:53 PM
KW Baraka's Avatar
OK...that's 29.4" tires.....
If your off-set ain't right....I'd say there's a good chance you'll rub the fenders/quarter panels with every time you hit a bump/imperfection in the road.
Check your clearance now to ensure that your tires tuck in. If they don't, that 1" to 1.25" drop can cause you issues unless you roll the fenders....
KW
