Power Steering Rebuilders - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 12-18-2015, 11:33 AM Thread Starter
Arkss's Avatar
I have been looking into who can build our reverse rotation pump now that Lee is out of the business and it's been difficult to find a good shop. While looking into a place to buy a PS pulley, I saw that Turn-one was building them, so I emailed them. It turns out that they do not make the pulley anymore, but they do rebuild our pumps. Here is the correspondence this far:
Sean,
We can, and have been, servicing the reverse rotation pumps for LT1 applications. We also have the ability to upgrade the pump to reduce horsepower consumption and reduce fluid temperatures, making the pumps longevity under high performance driving second to none. A standard rebuild starts at $100, if you would like us to upgrade the pump, it starts at $175.
As for the pulley, at this time we no longer produce a pulley for LT1 applications.
If you have any questions, please feel free to let me know.
Thanks,
Junior
Turn One Inc.
7436 E. Holland Rd.
Saginaw, MI 48601
989.759.4206 ext 701
I read through a post from 2014 that said they were not building reverse pumps at that time, so it's good to see that they now are. I'll be sending a pump to them in the next few weeks so I will keep everyone posted.
95 9C1 - T-56, 4.10's with Trutrac, Tri-Y's, Hooker cat-back, ERE42 Sitting in House
74 Silverado short wide - LT1/T56 Ready for Transplant
11 Xcab Silverado - 5.3/6L80E, 4/6 drop, exhaust, blackbear tune...
95 9C1 - Heads worked by Kuntz and Company, LE cam, tri-Ys, Hookers, "Dads Car" May he rest in peace
Arkss is offline
post #2 of 5 (permalink) Old 02-02-2016, 01:18 PM
The Bolt-On Terror's Avatar
How did this turn out for you?
I just talked to Jeff at Turn One today and he said they can't and never have done modifications to the B-body LT1 PS pump for reduced heat/load at high rpm. F body yes. Y body yes. 3 different LT1 pumps
Stock bottom 350, Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA SSuperPro Champion
2013 ISSCA SSuperNatural Champion
2013 ISSCA Roadrace Runner-up
2014 ISSCA SSuperNatural Runner-up
2014 ISSCA Autocross Runner-up
2015 ISSCA Roadrace Champion
The Bolt-On Terror is offline
post #3 of 5 (permalink) Old 02-03-2016, 08:34 AM Thread Starter
Arkss's Avatar
Additional Info
After seeing your post, I reached out again. This is what he said:
I have to apologize, I made a mistake when I responded to your original email. We can rebuild the pump, but we can not upgrade it in anyway. The parts no longer exist to upgrade your style of pump. We can rebuild it and return it to factory specs. The Impala uses a GM N style pump that is also reverse rotation. It is a very uncommon combination. I mistook it for the CB style pump that is used on the Camaro LT1. My apologizes. If you would like us to freshen up your pump, we would be happy to do so.
Thanks, and sorry for the mistake!
I shipped a pump to them for a general rebuild, so we will see how it goes.
Arkss is offline
post #4 of 5 (permalink) Old 02-03-2016, 08:45 AM
Since yesterday, I found this place:
http://www.pscmotorsports.com/
They CAN do internal modifications to the B-body pump, but only if your pump is in good condition (ie. there are two stock internal parts they mentioned that they can no longer get and are crucial to the modification process). From their description, it sounds like the mods aren't as extensive, and probably not quite as effective, as what Turn One does for the Y and F pumps.
I'm also going to pursue another option: trying to find a larger pulley that fits the B-body pump. Turn One told me no such thing exists, but I'll see how creative I can get. Also need to check if there is enough radial clearance between idler and alternator pulleys to accept a larger diameter PS pulley.
post #5 of 5 (permalink) Old 05-15-2016, 09:55 AM
Navy Lifer's Avatar
A larger PS pulley is very "iffy" with the B-body accessory package. It actually might be better to see if there's a way to make a Camaro LT1 FEAD work, but there's no simple fix, other than an underdrive on the crank pulley diameter (compared to stock).
Steering Technology Group
has resumed business from what was formerly Lee Manufacturing. If you're still in search of a solution on the pump side, contact them to see what's possible.
A (very) late response to this thread....but just wanted to provide some content that may be of value.
Bill Harper
ISSCA #127
[email protected]
Navy Lifer is offline
