91C Steering Box? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 12-22-2015, 09:36 AM Thread Starter
91C Steering Box?
I have a stock '94 SS in need of a new steering box/gear (leaking like a siv) I'm wondering if I can swap it with a 91C box for some tighter turning? Part # says for cars equipped with sport steering? But also says "All models"?? Can someone point me in the right direction. Thanks in advance,
aspico is offline
post #2 of 3 (permalink) Old 12-22-2015, 01:27 PM
SimplyTheBeSS's Avatar
I recall from the research I did when I needed to replace mine (Also have a 94' and wanted to go to the 9C1) that yes, the 9C1 box will fit/work on a 94'. I believe the only difference are the parts inside the steering box.
Make sure wherever you buy the box from that it is a 'good' box.
http://www.grail-ss.com/Steering_Box_Replacement.htm
1994 SS
SimplyTheBeSS is offline
post #3 of 3 (permalink) Old 12-22-2015, 08:57 PM
The SS box and the 9C1 box should be the same. You can also replace the seals on the original box if that is where it is leaking. I would also measure the Pittman arm just to make sure they are the same (I always take the Pittman arm when I pull a box). You may have to adjust the box for tightness. The instructions for adjusting the box are in the FSM.
Fred Kiehl is online now
