stock Impala SS springs? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 01-19-2016, 02:48 PM Thread Starter
Hi All,
I am looking to make my Roadmaster as close to stock Impala SS ride height and firmness as possible...I see the Impala springs are no longer made - what is the closest alternative? I really don't want a lowering spring if at all possible...I read through the sticky and all options listed seem to be at least 1" lower than Impala ride height.
Thanks!!
drhill is offline
post #2 of 4 (permalink) Old 01-19-2016, 04:56 PM
Here is a stock front set for sale on Ebay
http://www.ebay.com/itm/94-95-96-Che...lWkwmt&vxp=mtr
Here is a new aftermarket Impala Stock Springs for the Rear, or you can wait and see if a set of Stock Rear Springs come up in the future on Ebay
http://www.ebay.com/itm/Global-West-...xWYO-G&vxp=mtr
1996 BBB, K&N Intake, FB/HP Delete, AIR Delete,Billet Resonator Insert, TB Bypass, TPIS Air Foil, F Body EGR, Moroso 8mm Wires, NGK Iridium Plugs, HT 160 Thermostat, Magnaflow Hi Flow Stainless Cats, Pypes 2.5" X-Pipe, Dynomax VT Mufflers, Dynomax 2.5" Tail Pipes, KYB Shocks. BMR 1 1/4" Front Sway Bar, Rear GM Upgraded Lower Control Arms, Nitto 450s, PCM4Less 93 tune, Oil Cooler Delete.
kiefer9699 is offline
post #3 of 4 (permalink) Old 01-20-2016, 07:07 AM
May help
https://www.impalassforum.com/vBullet...ighlight=buick
post #4 of 4 (permalink) Old 01-20-2016, 12:19 PM
Z09B4U's Avatar
Ride height close But stiffer
I went from Hotchkis lowers to:
Moog 7268 Front Ford 150 97-03 Dodge Van 79-80
Moog 5419 Rear Caprice 79-96
With a tire with a stiff side wall they work for me. They are stiff but do not rattle your teeth. There are many posts about the 7268.
Z09B4U
Z09B4U is offline
