Power Steering Filter and Cooler Install - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 02-15-2016, 09:08 PM Thread Starter
Arkss's Avatar
After seeing a puddle of fluid on the garage floor one day, I decided to change the power steering setup a little since I had to replace the pump. There are two things that I felt were essential on the power steering system; a filter and a cooler. So I installed both when I swapped out the pump. I bought the following parts:
Filter - R038M-P Magnefine 3/8" Magnetic Inline Power Steering Filter
Cooler - DER-13254 Transmission Cooler 3/8" inlet/outlet
I had to route the lower pressure line coming from the steering box to the far driver side of the engine compartment in order to fit everything in the area. I cut the line just below the driver side fan and then used a bender to get it where I needed it.
I have a bead tool by Imperial that places beads on lines. Its great for stuff like this:
I used 90 degree brackets to mount the cooler. I ended up welding them together to ensure longevity.
I let the filter float between the cooler and the hardline that I fabricated that replaces a section of the rubber hose. I used rubber hose to help protect it against chaffing. Filter not shown below.
I hope this generates some creativity in finding solutions to some of the common problems in our PS system; Heat and Dirt.
95 9C1 - T-56, 4.10's with Trutrac, Tri-Y's, Hooker cat-back, ERE42 Sitting in House
74 Silverado short wide - LT1/T56 Ready for Transplant
11 Xcab Silverado - 5.3/6L80E, 4/6 drop, exhaust, blackbear tune...
95 9C1 - Heads worked by Kuntz and Company, LE cam, tri-Ys, Hookers, "Dads Car" May he rest in peace
Arkss is offline
post #2 of 6 (permalink) Old 02-16-2016, 07:02 AM
Looks good and I like/want that bead tool. I've done similar work in the past and just used a slight flare on the end of the tube. That Bead Tool is the "fashizzel" way to do it and I may need to look at getting one too.
For a cooler, I just added the 9C1 Return Line/Cooler that is a GM Bolt-on part. But compared to what you have for a cooler, it is just a Zig-Zag tube and most likely does not cool as well as yours.
For a filter, I chose this small unit since it was easy to splice into the Return Hose due to its size and can also be taken apart and cleaned.
http://www.amazon.com/dp/B005ETOQ3E/?tag=googhydr-20&hvadid=38274621807&hvpos=1s1&hvexid=&hvnetw=g&hvrand=14806447843556903906&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_5rdgmxhpzg_b
4DoorSS is online now
post #3 of 6 (permalink) Old 02-16-2016, 10:26 AM
[QUOTE=4DoorSS;11800281]. I've done similar work in the past and just used a slight flare on the end of the tube. That Bead Tool is the "fashizzel" way to do it and I may need to look at getting one too.
QUOTE]
yes that tool is what I would like to have also. Like you I just flared the ends. I have a cheap Harbor Freight tube bender & their flare tool
I used 3/8" fuel line clamps on mine. Pic below (I added a 2nd clamp on each one after pic was taken)
IMHO adding some form of cooler to PS is better.
Name:	PS cooler lines 2.jpg
post #4 of 6 (permalink) Old 02-16-2016, 11:23 AM
Hmm... I do like the "bead-tool" as well. I installed an automotive spin-on style filter mount,and additional cooler (to the 9C1 style) in front of the radiator.
post #5 of 6 (permalink) Old 02-16-2016, 08:56 PM Thread Starter
Arkss's Avatar
Additional Information
My dad was in the Air Force where he specialized in aircraft hydraulic systems. When he passed away I found myself with his car and some of his specialized tooling. The bead tools are actually made by Parker. Below are a few photos of the different size tools:
Here are a couple more photos of the filter installed and the loop that goes into the cooler:
Let me know if you guys have any other questions.
Sean
Last edited by Arkss; 02-16-2016 at 08:59 PM. Reason: Because I am better with numbers than I am words
Arkss is offline
post #6 of 6 (permalink) Old 02-16-2016, 11:36 PM
Cool back story on the tool Sean..
I too have some old tools from my Dad & Uncle that I will cherish forever. Don't make them like that now.
