Thoughts on Rebuilding Upper CTRL Arms W/Moog P/N: K6210 - Offset Shaft Kit? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 03-21-2016, 12:31 PM Thread Starter
juniorwatson's Avatar
All,
I'm getting ready to start some March madness upon my B-Body, and the first is by doing the front end suspension completely over. I've already purchased my Del-A-Lum CTRL arm bushings, and had the CTRL arms blasted & powder coated, and was getting ready to take the stuff over to my buddy to press in the bushings & ball joints. Then I got to thinking......
I've seen these pieces listed, but not known anyone to ever have talked about using these replacement upper center shafts.
**Moog P/N: K6210 - Offset Shaft Kit; Provides Additional Positive(+) Camber Adjustment**
Has anyone ever used these? Bad or good stories they'd like to share?
Now would be the time for me to get these and I'm looking for any input from anyone who's installed these on way or another?
As an FYI, during this March madness even, I'll also be installing 20" wheels & tires.
Thanks!
juniorwatson is offline
post #2 of 4 (permalink) Old 03-21-2016, 06:28 PM
I used the K6210 Shafts when doing the 5/8" ball joint install....
https://www.impalassforum.com/vBullet...d.php?t=351769
They worked fine and the only difference in these is they have "wheel Side" imprinted on the shaft that you want toward the wheel.
post #3 of 4 (permalink) Old 03-22-2016, 10:15 AM
offset shaft
I put these on my Impala but put them on to increase to camber setting without using a giant stack of shims. I set about 1* negative camber when I did the alignment.
Ken
Ken Hennessy is offline
post #4 of 4 (permalink) Old 03-22-2016, 04:06 PM Thread Starter
Gentlemen,
Thanks for the replies. It seems to make just good sense, and with the plan that literally *EVERYTHING* else in the front end system will be new, why cheap out on one part that will aid in not having a stack-up of shims, as Ken wrote.
One more thing purchased in the last week for the upcoming master overhaul!
