Sway Bar advice please - Chevy Impala SS Forum
 1Likes
  • 1 Post By 1slow96
post #1 of 7 (permalink) Old 04-25-2016, 04:35 PM Thread Starter
bigbodyss's Avatar
Talking Sway Bar advice please
Hey guys redoing my 21 year old suspension just got some new bilsteins sports 1104 and 0092 from summit, Now I need some opinions on sway bars because im Confused on which ones would be the stiffest there are Hotchkis, BMR, and hellwig, anyone know which ones are going to make the car stiffest? The thing I'm confused about is if the sway bar diameter is thicker does that mean they are also going to make the handling a little stiffer? is this a better thing? I see Bmr sway bars are a little bit thicker than the hotchkis ones, not sure about the hellwigg ones, any advice and knowledge would be greatly appreciated, thanks everyone I apologize Im new to suspension knowledge.
bigbodyss is offline
post #2 of 7 (permalink) Old 04-25-2016, 06:41 PM
I use/recommend Hotchkis bars. Stiffness is better to a point,and then works against one very quickly. With poorer traction,and very harsh ride the most common complaints. Hotchkis makes very good suspension components for these cars especially...
KW Baraka likes this.
post #3 of 7 (permalink) Old 04-25-2016, 11:00 PM
KW Baraka's Avatar
Originally Posted by bigbodyss View Post
......Now I need some opinions on sway bars because im Confused on which ones would be the stiffest there are Hotchkis, BMR, and hellwig, anyone know which ones are going to make the car stiffest?.....
If 'stiffness' was the only thing that was important in a swaybar, all the companies you named would be able to get your there. But what you really want is stiffness to a point where handling is improved but NOT to the point where your car feels like it won't steer 'true'.
I've had Hotchkis on my car '96 since 1999.....and Hellwigs were on my '95 when I bought it.
I like the Hotchkis a bit better for 'street' driving.
KW
KW Baraka is offline
post #4 of 7 (permalink) Old 04-26-2016, 09:58 AM
On a daily driver you can beat the BMR sway bars. I redid my 96 BBB suspension a few months ago with KYB shocks and Moog suspension parts. I added the BMR sway bar, cause my factory one was bent. I chose BMR, they are fairly cheap, great improvement and not to stiff in my opinion.
1996 BBB, K&N Intake, FB/HP Delete, AIR Delete,Billet Resonator Insert, TB Bypass, TPIS Air Foil, F Body EGR, Moroso 8mm Wires, NGK Iridium Plugs, HT 160 Thermostat, Magnaflow Hi Flow Stainless Cats, Pypes 2.5" X-Pipe, Dynomax VT Mufflers, Dynomax 2.5" Tail Pipes, KYB Shocks. BMR 1 1/4" Front Sway Bar, Rear GM Upgraded Lower Control Arms, Nitto 450s, PCM4Less 93 tune, Oil Cooler Delete.
kiefer9699 is offline
post #5 of 7 (permalink) Old 04-26-2016, 10:22 AM
^^^^+1
OP, consider getting the "sway bar brace" also....GP going on now.
Hotchkis bar with the F-Body Pro Touring brace
post #6 of 7 (permalink) Old 04-26-2016, 03:02 PM Thread Starter
bigbodyss's Avatar
Originally Posted by BALLSS View Post
^^^^+1
Yeah I see this Fbody brace on the front of the forum everyone been putting on, was also wondering if that would work if I choose to go with a BMR sway bar because its a little bit more affordable.
post #7 of 7 (permalink) Old 04-26-2016, 03:16 PM
Don't know why it wouldn't,as the mounting points are the same...
