Dick Miller Triangulation Braces Install? - Chevy Impala SS Forum
 1Likes
post #1 of 12 (permalink) Old 05-06-2016, 10:30 AM Thread Starter
juniorwatson's Avatar
Does anyone have any pix of Dick Miller's Triangulation braces installed?
Is new hardware required?
I was going to do some work on the rear suspension of my ride this weekend, and was finally going to install these that I bought years ago.
Just wondering if anyone who has installed can share some info.
Thx!
juniorwatson is offline
post #2 of 12 (permalink) Old 05-06-2016, 10:39 AM
jking1118's Avatar
I know I posted pics up years ago here when I installed mine. I recall several pics/threads about them.
Shouldn't need new hardware, and as long as your bolts are still in the "stock installed orientation" it should be pretty easy install. You might have to grind a little on one mounting bracket end depending on your mufflers.
Jonathan
jking1118 is offline
post #3 of 12 (permalink) Old 05-06-2016, 10:42 AM Thread Starter
Thanks Jonathan, I'll have to do a little better job searching next time.
P.S. I love you SIG Picture!
post #4 of 12 (permalink) Old 05-06-2016, 10:46 AM
jking1118's Avatar
Lol, what is it? It's not showing on my display for some reason. The one of the car in front of the American flags?
post #5 of 12 (permalink) Old 05-06-2016, 10:47 AM Thread Starter
Yes, that pic.
It didn't shop up in your last post for some reason, but in your initial reply, it's there.
post #6 of 12 (permalink) Old 05-06-2016, 11:05 AM
jking1118's Avatar
Yes, that pic.
Thanks. I love that pic as well. I won a ROTM here with it.
post #7 of 12 (permalink) Old 05-06-2016, 11:14 AM
I didn't take any pics of my DM install. Few notes I remember doing it:
1 bolts were facing towards inside of chassis
2 remove nut from bolt. I used box/open end wrenches. I also have Hotchkis upper & lower arms with their hardware which uses a "lock" nut so you need wrench on both ends
3 back bolts out so about 1/4" remains showing, put brace on bolts (they only go on one orientation), thread bolts back in (will need wrench to do) then nut back on bolt, tighten. What I found was without backing out the bolts I couldn't get the DM brace on with them extended out from control arms so backed them out. I may have only needed to back out the upper bolts. You will discover whether you need to do this when you try and get the brace on both the upper & lower bolts. On uppers space is tight and IIRC could only get 1/8 or 1/4 urns on wrench but very doable
4. you may need to unhook muffler/over axle pipe from rubber hanger and "push" aside for clearance to get hand/wrench on bolt.
5. I used jack stands under the axle housing and installed the braces with rear suspension "loaded".
Big Kahuna likes this.
post #8 of 12 (permalink) Old 05-06-2016, 12:06 PM
Still have not installed mine from that GP years ago...damn Mufflers are in the way. But I do have some pics at home from a thread I can't seem to find now. This link here shows them installed on Chris' car. There may be others, just Search "Dick Miller Braces" and you should find some more pics.
https://www.impalassforum.com/vBullet...8-post111.html
Believe you just remove the HW for the Control arms and these slide in place and the Nuts remount over the braces. Think I remember seeing where you had to push the bolt out to where it was flush in order for the brace to slip into position. Then just push the bolt back out through the brace and reuse HW.
EDIT - Missed BALLSS post above but Step #5 is very important on any suspension work.
post #9 of 12 (permalink) Old 05-06-2016, 12:49 PM Thread Starter
Thanks for the follow-up. I've got to get together with my hardware supplier Monday, and get some new Ny-Loc nuts for this install, and then I'll be good to go.
post #10 of 12 (permalink) Old 05-06-2016, 02:44 PM
Chicagoareabmx's Avatar
Send a message via AIM to Chicagoareabmx
I installed mine with the suspension unloaded on a lift. Re-used all the stock hardware. Seems like they work pretty well.
MAKE SURE that you have 2 different parts. They ARE side specific. I sat on mine for months before attempting the install, only to find out Dick Miller accidentally sent 2 LEFT side parts. D'oh! They took care of it immediately though.
Did you find any pictures?
Brian
95 LT1/T56 9C1
Gettin REAL FUN!
Road Course Vids:
http://www.youtube.com/channel/UCPWe...UPeQEew/videos
Chicagoareabmx is offline
