Rear Lower Shock Mount - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 05-24-2016, 09:18 AM Thread Starter
Fullmoonboogie2002's Avatar
I installed a pair of Monroe Severe Service shocks a couple weekends ago and found the bottom bolt holes to be oval instead of round. A couple weeks later, I can feel the movement in those bolts again even after tightening the crap out of them with my impact wrench. What is the best way to remedy this? I was thinking of welding a large washer to make the bolt hole round again. Any other ideas?
Greg
1994 Caprice Wagon-3.42|Impala SS Wheels/9C1 Wheels|Centrix Rotors|Fleetwood J55 Calipers|Koni Fronts, Monroe SS Rear|Bonneville 6 ways|Z28 Cluster|Pypes X-pipe|Dynomax Super Turbo's|[email protected]
1991 OCC|'93 Z28 LT1| ZZ4 Cam|SLP TC|Home Depot CAI - SOLD|[email protected]??
1983 Camaro Z28-I bought it new|5 speed|350 4 bolt|'90 Corvette heads, SLP headers and 3" exhaust|Konis|4 wheel discs|3.73. SOLD
2002 Regal GS|XP Comp Cam|SLP headers|3" downpipe|3.3 pulley|[email protected] (traction limited) SOLD
Fullmoonboogie2002 is offline
post #2 of 3 (permalink) Old 05-24-2016, 12:17 PM
Decades back I had luck on a hogged out hole by grinding a tiny piece of smooth rod that roughly fit the worn space and shaped to keep the bolt immobile. I made it ever so slightly thicker than the material gauge it was going in, and used stout washers to squeeze it in there and make sure nothing moved around.
With access to a welder your idea is way better - other than filling and drilling whole new holes.
post #3 of 3 (permalink) Old 05-25-2016, 05:31 AM Thread Starter
Thanks for the tip on using a spacer. My son has a welder knows welding and I doubt I could weld well enough to get the job done. In case I can't match schedules with him, I will try to make a spacer like you did.
