90+% of the benefit. 1% of the labor and cost. - Chevy Impala SS Forum
 2Likes
post #1 of 14 (permalink) Old 09-03-2016, 02:36 PM Thread Starter
A boxed frame is heavy, cost$$ and only returns a small improvement in anything that matters. This is true if sad. BUT if you could have 90+% of any boxed frame benefit for only 2 hours of labor and 1% of the cost$$? Thank the member who hates posting but wrote me a PM. The Metal Store: M-F 8am-4pm; Order Online or Call (216) 663-0458. You must measure the C-channel carefully for easy installation but you'll buy 3/16" steel plate, cut somewhere around 3" X 5" of your car's C - channel. No need to lift the body, no issues with heat. 16 pieces will do a sedan, cost ~ $100.00 U.S. if I've got the $ conversion rate right. Then weld in half on each side roughly equally spaced. You'll alter the leverage points of the frame which now is about as strong as a 2 X 4 that long bent over a saw horse ( from roughly the distance of your wheelbase) to 14" (Like really stronger). If you are crazed you'll cry about the added weight. Each steel plate weighs a few ounces. If you are crazed you could use a frame machine for an hour to get your frame closer to spec but they might commit you. Sunday Go To Meeting Cars (or Taxi's or The Blues Mobile's) Forever. You hate this? Shut up and ignore it, you're already on the ignore list.
nsaness and gbhs72 like this.
scot is offline
post #2 of 14 (permalink) Old 09-05-2016, 11:15 AM
It sounds like cutting out a bunch of coped shapes to match the inside profile of the frame for evenly spaced gusset-spreaders. Yes-no??
Just confirming for me and over 110 other guys out who've seen this.
Originally Posted by scot View Post
You must measure the C-channel carefully for easy installation All frames are the same, within a 1/4"+- maybe. Cadys and wagons maybe a touch thicker gauge - maybe. What am I measuring on the frame, and where? Is this just to get a cardboard template?
....cut somewhere around 3" X 5" of your car's C - channel. I'm cutting on the frame? I thought we'd just be welding in fillets.
You'll alter the leverage points of the frame which now is about as strong as a 2 X 4 that long bent over a saw horse ( from roughly the distance of your wheelbase) to 14" (Like really stronger). [U]Ok, 8 pieces per side about 14" apart is way longer than the distance between the A-piller and the rear axle hump. What gives?? do you have us doing behind the axle too?[U]
post #3 of 14 (permalink) Old 09-05-2016, 12:36 PM Thread Starter
Yes
Make'm yourself is even cheaper than The Metal Store.
"ou must measure the C-channel carefully for easy installation All frames are the same, within a 1/4"+- maybe. Cadys and wagons maybe a touch thicker gauge - maybe. What am I measuring on the frame, and where? Is this just to get a cardboard template?"
That will work, rough sizing because your going to weld in anyway. Do not weld fuel lines/brake lines. Bad idea.
NO frame cutting! I thought we'd just be welding in fillets."
That's right! Gusset can be welded only top and bottom or at sides where lines are not an issue.
Frame thickness
Civilian Caprice is 0.100"
RMS 0.110"
WX3 0.125
FW 0.135"
scot is offline
post #4 of 14 (permalink) Old 09-05-2016, 12:48 PM Thread Starter
PS
"All frames are the same" you wrote.
20-22 years of bashing, flexing, cop cars bouncing on curbs, jacks used by morons, and two dozen other exceptions to the "All frames are the same". You enhance what 22 years gave you. Strong frame good. Weak frame bad.
scot is offline
post #5 of 14 (permalink) Old 09-05-2016, 12:56 PM Thread Starter
"Have IQ's ..."
That's Pillar...
No these pictures show what you do behind the axle. Little bend in the tube for the gas filler. Spot weld one side, take BIG hammer, bang into other side (Putting tension on the frame rails makes this stronger) weld both sides and done.
The C-channel's only an issue on the run of the wheelbase. So the pieces welded in @ 14" apart are only between the wheels. 8 pieces for overkill or dealing with the holes for the body bushings so sometimes one piece on either side of the hole.
"You must measure the C-channel carefully for easy installation but you'll buy 3/16" steel plate, cut somewhere around 3" X 5" of your car's C - channel."
3/16" plate cut ...not the frame. I only use English about 5% of the time now. Does it show?
Name:	St .135 94 Impala.jpg
Name:	St .135 Impala 94.jpg
scot is offline
post #6 of 14 (permalink) Old 09-05-2016, 01:28 PM
Copy All - And Payback's a Bitsk
That will work, rough sizing because your going to weld in anyway. Do not weld fuel lines/brake lines. Bad idea......
FTR it's "you're"
And it's "morans" thank you very much. My hometown team SMH
Seriously, thanks for the added details.
post #7 of 14 (permalink) Old 09-05-2016, 01:29 PM Thread Starter
Being as you gonna be weldin
Do the Pro-Touring F-Body frame brace right (optimal means no rattles,no broken plastic radiator from inappropriate intrusion, no added road vibration, harshness on and on)
"3/16" plate cut ...not the frame. I only use English about 5% of the time now. Does it show?" AND...
"That will work, rough sizing because your going to weld in anyway. Do not weld fuel lines/brake lines. Bad idea......"
Correct the above to weld IT in ..if you need to correct it, or corect it or co erection...
5% Wha be ya axcus?
And anyway the "That's Pillar" was supposed to evoke "That's Hedley"
https://www.google.com/webhp?sourcei...marr%20youtube
Name:	94 SS welded-painted.jpg
scot is offline
post #8 of 14 (permalink) Old 09-05-2016, 02:14 PM Thread Starter
Pro-Touring web site
Sway bar brace
2CF-842 $65.00
also fits 91-96 impala; Note, will not fit with hollow sway bars.
Before weld pictures of the Hellwig 1 3/8" hollow front sway bar referred to above. Pro- is right, it won't fit without the spacers (and a little wittle at the back of the brace) For those with any 1 1/4" solid front bar, or smaller, or the Hotchkis Hollow 1 7/16" front bar, or the Quickor 1 3/8" hollow front bar, you do not need the spacers. To avoid inappropriate contact with the lower radiator hose you might/might not need the wittle (it's a word in English)
Combine it with my rear frame rail brace (disparagingly referred to elsewhere as "some kinda homemade" by the pathetic and sad unworthy now consigned to the ignore list. See [url="https://www.youtube.com/watch?v=9-tYZkJ2p54"] and DMR frame braces ( Co-Miller brainstorm in 1994 for SVI cars) and the C-channel weld ins (of course) for 95+% of a custom Progressive boxed $6000 in 1994 frame for ~2% of the cost and effort. For what it cost and the effort of the change over, that $$$$ frame was a big let down. At ~2%=big smile.
scot is offline
post #9 of 14 (permalink) Old 09-06-2016, 10:37 AM Thread Starter
"You Americans...
...always over dressing for the wrong occasions."
If this quote eludes you I mourn your misspent youth. Or maybe it alludes to your not misspent youth.
AND "That's Hedley"
Originally Posted by 96 Black View Post
FTR it's "you're"
scot is offline
post #10 of 14 (permalink) Old 09-06-2016, 10:54 AM
91ss's Avatar
English and math not so good. lol. The channel section measures about 40" each side. One side is a little longer than the other. Not sure how you expect to weld in 8 pieces @ 14" apart in that 40" space. Maybe you are using metric system.
91ss is offline
