Gm C body interchangeable - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 09-17-2016, 08:22 AM Thread Starter
cr2motorsports's Avatar
Read somewhere that GM C bodies and D bodies share alot of the same parts as the 77-96 B bodies, with the exception of the frames being wider and/or longer but the trailing arms or some the of the suspension components are the same or interchangeable.
An acquaintance of mine has a 76 Caddy Seville/ Deville 4 door and wanted to.know if the current 77-96 B body aftermarket trailing arms will work , or the 70 -76 ones will.
Thanks
cr2motorsports is offline
post #2 of 6 (permalink) Old 09-17-2016, 09:38 AM
Originally Posted by cr2motorsports View Post
..... An acquaintance of mine has a 76 Caddy Seville/ Deville 4 door ....
Thanks
It may not matter, but better to clarify which anyway. The '76 Seville was pretty much a fancy Nova, and the other was the more fullsize.
96 Black is online now
post #3 of 6 (permalink) Old 09-17-2016, 11:46 AM Thread Starter
Fullsize...Deville
post #4 of 6 (permalink) Old 09-17-2016, 12:18 PM
jayoldschool's Avatar
77-96 Deville/Fleetwood is the same basic chassis as the 77-96 B body. They were originally named C body, and changed to the D body designation in the early 80s. They are on a different platform than the Seville. The rear arms for coupe/sedan B/C/D will interchange.
jayoldschool is offline
post #5 of 6 (permalink) Old 09-17-2016, 01:19 PM
An acquaintance of mine has a 76 ...
Thanks
I think the brunt of the question is whether the suspension pieces from the "original original larger real fullsize '76 and earlier" will fit the "downsized '77 onward" type chassis as ours is. I admit I don't know right off.
I checked Hotchkis site and they have a listing for rear trailing arms 65-70 and another for 77-96, but no apps in between. Leads me to believe the latter is not interchangeable with the older big chassis before downsizing. Let's hear otherwise though.
post #6 of 6 (permalink) Old 09-17-2016, 08:02 PM
Did you try measuring them, and comparing them with the length of the others? Check the bolt size as well.
