Correct Jeep steering shaft? What other parts do i need? - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 10-31-2016, 02:00 PM Thread Starter
TABlaylock31's Avatar
I believe this is the jeep steering shaft that is used to replace the impala shaft. Bought this a while back just making sure its the correct 1. Also what other parts will i need to R&R the old shaft? Steering is getting very sloppy and its time to do the change. thanks guys.
96 BBB Impala SS
TABlaylock31 is offline
post #2 of 6 (permalink) Old 10-31-2016, 05:16 PM
All Star's Avatar
Yes, that is one of the correct style shafts. Just unbolt your old shaft, you may have to use a small hammer to get the old shaft to collapse so you can remove it.
All Star is offline
post #3 of 6 (permalink) Old 10-31-2016, 07:41 PM
You must put a groove in the end of the steering column shaft to allow clearance for the clamping screw to go past the shaft. There is a slight interference.
The shaft you got is the better and easier of the two styles to use.
post #4 of 6 (permalink) Old 11-05-2016, 12:56 PM Thread Starter
So i dont need any other parts? Just make the groove then its "plug and play" basically?
96 BBB Impala SS
post #5 of 6 (permalink) Old 11-05-2016, 03:03 PM
You still must collapse the jeep shaft. Do not beat on the end. If you put pressure on the universal joints, you can damage them.
Measure the distance that the upper sleeve goes over the column end, and mark it at the hole for filing. You can use a small round file, or Dremel tool with a grinding wheel/cutter to make the slot. The column is fairly soft steel.
post #6 of 6 (permalink) Old 11-05-2016, 06:50 PM
Good link as it has install picks which should help show what you need to do.
https://www.impalassforum.com/vBullet...9-post140.html
Edit - from what I remember seeing/reading elsewhere, you don't need to grind much of a groove in the steering column. Just put the bolt through the jeep shaft, look in the end and see how much of the bolt is exposed to determine how big to grind the groove.
