Steering box fitting sizes??? - Chevy Impala SS Forum
 4Likes
post #1 of 74 (permalink) Old 11-18-2016, 02:07 PM Thread Starter
smelonas's Avatar
I searched, I tried many different searches and read a lot of threads to no avail. One thread was on here where the guy added one of those tube coolers.
I did find a small amount of info about the style they are (inverted flare?) but not the size. Go figure.
I see pictures on rockauto of the end as well, and of course its the same style that go into the back of the PS pump.
So I guess now my question changes mid post.. Can I just use an inverted flare fitting? or will I need to find a compression fitting to clamp on the hard line wherever I decide to cut it? What is the OD if I decide to go compression? I would look myself, but my car is at home and I would like to order this stuff now. Need to get a damn flaring tool really.
With this, I am trying to add a PS cooler to my system, since I overheat the living crap out of it!! Thanks dallas.
Mods, all the free good ones.
smelonas is offline
post #2 of 74 (permalink) Old 11-18-2016, 04:29 PM
I guess you're talking about the fitting or nut size of the hose end? If so, I seem to remember they were in the 16 -19mm range but not certain as I have a set of flare wrenches and can't remember which was which. I looked up specs on the pressure hose and it shows the 2 sizes there for the fittings. Looks like the pressure hose is 16mm and 18mm on the other end
MasterPro Power Steering Hose 91780 - Power Steering Hose | O'Reilly Auto Parts
Keep in mind that these fittings are specialized and have an o-ring on them. If you want to convert over to something else, Russell and others carry these fittings to use.
It also sounds like you are considering cutting the line and going with compression fittings. I would not do this on the pressure side since the pressure will exceed the rating of that. You may be ok to do that on the return side though.
You can add a stock cooler made for the 9C1 (police package) cars. The return hose for this car is about $11 more than the standard return hose. I added this setup along with an inline filter and there is instructions on what you need to do this factory setup in I think the impalass technical archives.
post #3 of 74 (permalink) Old 11-18-2016, 05:28 PM
You can only put the cooler on the return side. The OEM cooler line is just a piece of metal line. You could make a zigzag or coil the line yourself to give it more length for more cooling. Regular hose clamps will work fine, and you can make an unfinished double flare to act as a flange to keep the hose from slipping off.
post #4 of 74 (permalink) Old 11-18-2016, 05:42 PM Thread Starter
smelonas's Avatar
The technical archives don't work for me. The site is there but the links don't work...
Yes, I wanted to add a cooler on the return side of course. I think I'll do it close to the same way I did my tranny cooler. I ordered a 12 by 7.5 inch derale cooler. It's fittings are 3/8 barb. I guess I'll just plumb that in with barb fittings and hose clamps.
Good to know that companies makes that goofy extended flare fitting that goes in and out of the steering box. I boiled the fluid the other day in traffic so this has become a big rush thing to get this done now. I wanted to do one before but I was going to wait....
Also I was asking for the fitting size. So thread diameter, not nut size. But thanks anyway! Still good to know!
Sent from my SM-N910V using Tapatalk
smelonas is offline
post #5 of 74 (permalink) Old 11-18-2016, 09:39 PM
That Derale cooler sounds nice, post up some pics when you get it done.
Here is the 9C1 Cooler/Return hose from AZ for only $30 and fit just like GM....the standard return line for the Impala is about $20.
It just Zig-Zags along the bottom of the Rad Support and back to the Reservoir.
Here is the CUTnPASTE of the 9C1 Cooler Mod from Goldsswagon.com site....
Installing the SEO Power Steering Cooler
Advantages
Keeps the power steering fluid cooler than the just the stock unit, which is a good thing, especially if you autocross you beast.
Disadvantages
Additional hose routing needed, blocks some flow to the radiator.
Parts Required:
  • 1 Pipe Assembly, (GM P/N 26036034), $???
  • 2 Clamp-Lo (GM P/N 2091638), $???
  • 10 pack of bolts, (GM P/N 11509363), $???
  • 2 Nut, RR BP, (GM P/N 12337917), $???
  • 32 oz of GM Power Steering Fluid
Total cost is around $50.
Tools Needed:
  • 10mm wrench
  • 8mm wrench
  • Floor Jack
  • Creeper or something else to lay on underneath the car
Procedure (from Basim Jaber):
  1. Park the car, place blocks at rear tires, and set the parking brake.
  2. Siphon, pump, or drain the power steering fluid from the reservoir.
  3. Detach the reservoir from the bracket (it slides up), and detach the fluid line from the reservoir. This is the one closest to the front of the car. Save all of the protective sheething for reuse later!
  4. Tape up the end of fluid reservoir line to avoid spillage
  5. Jack up car and remove the clips that hold the two power steering lines. Tthey are under the motor along the frame cross member.
  6. Slide the plastic steering shaft cover off of the power steering fitting and unhook the two fittings from the power steering gear. Beware: this is a knucklebuster job! Use an 18mm wrench here, and watch out for draining fluid. Unhook the forward one first.
  7. Remove the power steering line in question that is to be replaced with SEO 7L9 tube assembly.
  8. Insert the tube assembly. The RH side goes under the coolant hose, and the LH side goes underneath (or possibly between, if it will fit) the oil cooler lines. Getting the RH side underneath the coolant hose will be snug, so hang in there.
  9. Hook up the cooler hose line to the reservoir using the stock clamp, and slide the reservoir back onto the bracket.
  10. Install the screws that hold the tube to the radiator frame housing using a 10mm wrench. Tighten them later, after fitting everything else, especially the cooler fitting to the power steering gear.
  11. Install the SEO cooler fitting to the power steering gear and tighten well. Note that if you take off the left wheel, there's more clearance to get a wrench in there from the side.
  12. Slide the plastic shaft cover back over the fitting.
  13. Install the stock inflow line back into the power steering gear and tighten well.
  14. Fill the reservoir with new fluid. Fill until the "C" mark (full cold) on reservoir cap is reached.
  15. With cap off reservoir, turn the wheels lock to lock 40 times.
  16. Lower car to ground, and check that fluid level is still at "C". Add if necessary
  17. Start the car, and turn the wheels lock to lock for two minutes.
  18. Check the fluid again, and add as necessary.
  19. Replace the fluid reservoir cap.
The hardest part of this mod is disconnecting/connecting the fittings to the p/s gear unit. There isn't much hand room and the wrench can only turn about a 1/8th of a turn in either direction. Consult the service manual for the standard precautions and more information on this mod.
A few pics of my install and the little Filter I spliced in near the Battery before going back to the Reservoir...
smelonas likes this.
post #6 of 74 (permalink) Old 11-19-2016, 06:24 AM Thread Starter
smelonas's Avatar
Nice! Sweet. I saw your post as I was searching, pretty nice little setup!
Yeah I'm going to go for real on this cooler. Thought of doing a 2 or 4 pass one, but I thought to myself, well I'm going to be in it this far... lol it will look exactly like my tranny cooler.
Here's my plan, take the metal return line at the gear and cut it, add compression and barb fitting. Route 3/8 hose around rad to top inlet of cooler. Then go straight from cooler to reservoir. That last step will probably occupy an hour of my time. I need to make sure it is routed as smoothly as possible to allow 3 gallons per minute of flow.
There can be no backpressure. That's what Steve over at LEEs told me.
smelonas is offline
post #7 of 74 (permalink) Old 11-19-2016, 09:04 AM
juniorwatson's Avatar
OP, As an FYI I have both of these lines new in the bag in the trunk of my car.
I was going to replace them when I installed my rebuilt P/S pump, but I could not break the fittings loose on the gear box at all.
So I decided that will be a future project when I have some room to play around when I install the rebuilt engine I have in storage.
If you want any pictures or details, let me know.
The size of the hex fitting in the gearbox was 16MM, I don't recall if it was 18 or 16 on the back of the pump, but I'm leaning toward 16.
juniorwatson is offline
post #8 of 74 (permalink) Old 11-19-2016, 09:39 AM Thread Starter
smelonas's Avatar
I borrowed my buddies flare wrench set to do my PS pump. I think they were 5/8 or 11/16. Came right loose.
Have you guys tried putting Kroil or PB on those bolts at the gear a long time before you planned on taking it apart? I sprayed the cooler fittings on my radiator with that stuff a month before I planned on replacing it. They literally came right off. Where as before I sprayed them, I tested how easily they would come off and they would not budge.
Try putting that stuff on a few weeks before. It should really get in there and those fittings should just pop right off.
smelonas is offline
post #9 of 74 (permalink) Old 11-19-2016, 01:24 PM
Are you mounting the cooler up next to the stock ext tranny cooler where the stock engine oil cooler goes? I've also seen someone had a finned tubular style cooler they ran the length of the rad support.
If I was putting the cooler up front and wasn't going AN and braided, compression fittings would be the next best thing like your considering. Rather than running rubber hose through the rad support and back o the reservoir, I may try to run some steel line that you could bend up. Then cover that line with rubber hose where it passes through tight areas. You could probably get real tight to the frame and keep the line more secured than rubber hose. Maybe even borrow some items/ideas from the 9c1 setup.
Use PB Blaseter myself and good idea to soak them fittings for days. A lot of the "stickiness" of the fitting is it gets fused to the metal line and can often twist the metal line as you back out the fitting. I like to get as close as I can to the back of the fitting and the steel line with emery cloth and clean the fitting/metal line of rust and crud. Then before backing off the fitting, try to give it a little tighten first to break the seal.
post #10 of 74 (permalink) Old 11-19-2016, 03:02 PM Thread Starter
smelonas's Avatar
Yes! Tighten to loosen has always been a lost forgotten trick. Dumbest sounding thing ever, but it works as a last resort.
If you look at my post for my tranny cooler, it will literally be a mirror of that. So basically any airflow going through the grille will have to pass through one of the two coolers lol. Or go underneath them... either way. I'll just snake the line around the radiator support like the stock steel tranny lines and them go from there.
Should be extremely effective and easy to do. I need this fluid to stay cold. If I could keep it at 80 degrees, I would. Not being able to use synthetic really blows this whole system up ya know?
smelonas is offline
