PS problems - Chevy Impala SS Forum
 9Likes
post #1 of 43 (permalink) Old 03-27-2017, 04:32 PM Thread Starter
CHILNLO's Avatar
PS problems
Ok almost every morning for the past month my power steering won't budge until I give it a little gas. It will whine for a minute and work perfectly all day long. This ONLY happens in the morning at start up.
I'm thinking maybe an air bubble in the system? Anybody else had this problem?
Sent from my XT1585 using Tapatalk
1996 Chevy Impala SS
Cali-SS
CHILNLO is offline
post #2 of 43 (permalink) Old 03-27-2017, 04:43 PM
I'd start by changing fluid at the very least. I use/recommend Red-Line P/S fluid personally. System doesn't hold much,so cost of fluid is reasonable...
1slow96 is online now
post #3 of 43 (permalink) Old 03-27-2017, 04:52 PM
juniorwatson's Avatar
OP, If you decide to go this route, let me know, as I bought some redline at the time I had my unit rebuilt by Lee P/S. Steve told me that he wouldn't recommend using the stuff on his rebuild, so I didn't use it.
It's taking up shelf space for me so......
juniorwatson is offline
post #4 of 43 (permalink) Old 03-27-2017, 05:11 PM Thread Starter
CHILNLO's Avatar
What did he recommend?
Cali-SS
CHILNLO is offline
post #5 of 43 (permalink) Old 03-27-2017, 06:34 PM
The stuff he sells,most likely. Nothing wrong with Red-Line. Tolerates high temperatures,flows good when cold,and keeps passages clean...
CHILNLO likes this.
post #6 of 43 (permalink) Old 03-28-2017, 12:17 PM
did you check to see if the Belt/Pulley isn't slipping? As mentioned, try a Flush first and bleed the system to see what that does and check your tensioner. doubt an air bubble would cause this as that would have probably bleed off already.
You could just have an old Pump that is tired and time to rebuild/replace.
post #7 of 43 (permalink) Old 03-28-2017, 12:26 PM
smelonas's Avatar
Steve told me to not use synthetic fluid, outside of that he said any power steering fluid is fine.
I would use the ACDelco brand power steering fluid honestly. Using valvoline PS fluid and I have been having problems trying to get my steering to be quiet and silky smooth like it was when I had Royal Purple in it, BEFORE the rebuild.
If your old pump goes out, have it rebuilt by LEE. I would add a cooler too. I have a thread on that.
In your case, I would go get a 2 or 3 quarts of power steering fluid, then bleed bleed bleed. Cant really bleed enough honestly.
I think my gear needs to be rebuilt as well now so maybe thats my problem. Or maybe I ruined the pump by boiling the fluid 3 days after I reinstalled the pump. Its costing me way to much money at this point. Hence why I recommend to you to install a cooler..
CHILNLO likes this.
Mods, all the free good ones.
smelonas is offline
post #8 of 43 (permalink) Old 03-28-2017, 12:26 PM Thread Starter
CHILNLO's Avatar
No belt/pulley is good as well as the tensioner. I have replaced the PS pump before because it was hard turning and only felt smooth when pressing down on the gas. This time around it's only at the first start up. I daily drive mine so when I go for lunch or go home from work there is no problems.
But what would be a good way to flush out ALL the fluid?
Cali-SS
CHILNLO is offline
post #9 of 43 (permalink) Old 03-28-2017, 12:30 PM Thread Starter
CHILNLO's Avatar
Yes if it does go out I'll definitely go to Lee's since I live in the same city as their shop. By the way what's the link to your thread?
Cali-SS
CHILNLO is offline
post #10 of 43 (permalink) Old 03-28-2017, 12:39 PM
smelonas's Avatar
https://www.impalassforum.com/vBullet...ing-sizes.html
Here is the circle jerk that was... I didnt go into much detail about the install... I need to post up finished pics to that thread so that its 'complete'. That was a trying time for me last year.
smelonas is offline
