Axle Spring Brackets - Chevy Impala SS Forum
 1Likes
post #1 of 11 (permalink) Old 03-27-2017, 05:35 PM Thread Starter
Sshockr's Avatar
I've decided the time has come for me to correct the weird spring angle I have due to lowering and axle relocation.
Yes, I've measured all the angles and dialed in the pinion angle correctly. So since future plans do include airbags I though I might as well fab up a bracket that'll do double duty.
After getting the whole car in the air and level and the rear axle supported at ride height without the springs installed, I proceeded to drop a plumb bob and start making a bunch of measurements. The result is the other photo.
Similar to many jeep offset brackets, I picked up some 4"x4" 3/16th Wall Square Tube this weekend to cut the brackets out of.
I will post photos as I go.
I guess the one question I do have at this point is could this possibly be welded using a 110v Lincoln MIG with flux core if I take my dear sweet time and weld both sides of the flanges to the axle shaft, or will I end up tacking it then pulling the axle and hauling it to somebody with more power?
-Brian
'95 B4U LT1/T56 in Purple Pearl. 24x 355 with I believe most of the bolt-ons.
'63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags.
'06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me.
Still in Wichita.
Sshockr is offline
post #2 of 11 (permalink) Old 03-27-2017, 06:48 PM
I think you are asking a lot from your 100A welder.
post #3 of 11 (permalink) Old 03-27-2017, 08:00 PM Thread Starter
Sshockr's Avatar
Guess it's time to clean up the 230v Miller Thunderbolt and learn to stick weld.
-Brian
Still in Wichita.
Sshockr is offline
post #4 of 11 (permalink) Old 03-28-2017, 07:50 AM
91ss's Avatar
Some food for thought. Not sure how significant it will be, but you'll be inducing about 100 ft-lbs of torque to the axle going by that sketch.
May actually help on drag launches being it's pushing the yoke downward. Other times...??
91ss is offline
post #5 of 11 (permalink) Old 03-28-2017, 05:10 PM Thread Starter
Sshockr's Avatar
I did think about that however, My spring centerline will still be slightly over the tube. If you look at 60's Chevelles and Elkys they all have spring perches with the CL almost 2" ahead of the axle tube while still using the same 4 link suspension style. The airbag set up from Riderite has angled and offset perches. So while yes it will induce a little extra load in the upper links, I'm not too worried about it.
-Brian
91ss likes this.
Still in Wichita.
Sshockr is offline
post #6 of 11 (permalink) Old 05-02-2017, 05:16 PM Thread Starter
Sshockr's Avatar
Update
Some updated photos from cutting the brackets and getting them test fit.
The cardboard tube is cut to the ride height of the spring and allowed me to make sure all my measurements were good before welding.
Got one side welded in before environmental conditions in my garage shut me down for the weekend. I'll get some photos with springs installed this weekend.
-Brian
Still in Wichita.
Sshockr is offline
post #7 of 11 (permalink) Old 05-02-2017, 06:15 PM
When you've been measuring and welding, have you had the axle at ride height?
threeimpalas is offline
post #8 of 11 (permalink) Old 05-02-2017, 06:40 PM Thread Starter
Sshockr's Avatar
Of course. That's why I have the white cardboard tube cut to match the compressed height of the ST springs I run.
-Brian
Still in Wichita.
Sshockr is offline
post #9 of 11 (permalink) Old 05-03-2017, 06:45 PM
k gee's Avatar
-Brian
I don't miss the days of 3/4" extended trailing arms and ST springs. I redid the shocks last weekend and even with Hotchkis extended arms and springs, STILL don't like the new angle.
Your job looks good.
96 DCM Caprice B4U
96 RMW Collector's Edition *Sold*
www.cali-ss.com
k gee is offline
post #10 of 11 (permalink) Old 05-03-2017, 08:05 PM Thread Starter
Sshockr's Avatar
I finally kicked this project into gear after I drove home on a sideways spring from when I gave up on o2 sensor removal and took it to a shop.
-Brian
Still in Wichita.
Sshockr is offline
