P.S. Gear Box line fitting size - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 04-01-2017, 01:17 AM Thread Starter
AnimeFunTV's Avatar
Question P.S. Gear Box line fitting size
Hey guys,
I was wondering if by chance anyone would happen to know what size is the fitting on the PS hose going into the Gear box for a 94 b-body. I plan on converting it to a AN fitting for my LS 6.0 build and Russell has several adapters Power Steering - Adapter Fittings - Russell Performance Products but not exactly sure what size adapter I need.
AnimeFunTV is offline
post #2 of 6 (permalink) Old 04-01-2017, 11:49 AM
4x4high's Avatar
One is 16mm and the other is 18mm.
648060 and 648080
1996 DGGM Impala SS
4x4high is offline
post #3 of 6 (permalink) Old 04-01-2017, 12:14 PM Thread Starter
AnimeFunTV's Avatar
648060 and 648080
Thanks! You're a life saver!
post #4 of 6 (permalink) Old 04-01-2017, 01:45 PM
This is a recent thread that has that info as well as some other you may find useful.
https://www.impalassforum.com/vBullet...ing-sizes.html
Once you get things converted over to AN/Braided, let us know what you came up with and post up some pics. There may be others interested in this conversion as well and what the parts cost along with how you secured everything. You may have to use some sort of hard line around the PS Pump area as space is tight there.
post #5 of 6 (permalink) Old 04-01-2017, 08:17 PM
gbhs72's Avatar
If you're interested. Jegs has 100705 16x1.5 to AN-6 and 100706 18x1.5 to AN-6. Each one is $5.99
Mark: Snowman-33
gbhs72 is offline
post #6 of 6 (permalink) Old 04-02-2017, 12:01 AM Thread Starter
AnimeFunTV's Avatar
Sounds great, I plan on moving pretty quickly with the swap. I already have the old LT1 removed and sold. Gotta clean the engine bay and do only a few detail before the 6.0 gets dropped in.
