Airlift bag blown. Replace airbag or go with air shocks? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 05-12-2017, 08:55 AM Thread Starter
I trailered a car with my '95 Caprice wagon from Chicago to Memphis for an event. On the way down, the Airlift system won't hold air. I assume blown bag. Nobody seems to have a replacement in Memphis before I make the trip back on Sunday. If anyone has a place I can try, let me know.
I see some companies make air shocks. Any advantage of air shocks vs air bags?
FYI, I'm at the fbodyevent ? fbodyevent . We started out more than 20 years ago as f-body only but now it's anything you want to bring. If you want plenty of drag race, autocross, or road course time this is a great event with a small group of enthusiast friends that have been doing this for a couple decades. New friends always welcomed to join the fun!
1995 Caprice Wagon
1996 Caprice 9C1
Winger67 is offline
post #2 of 4 (permalink) Old 05-12-2017, 09:59 AM
A new entire set runs ~$100 nowadays, - up from $70 a few years back. You can of course contact Airlift to see if single pieces are available - likely 2/3 the cost of a new set. I had a bag blow after 15 years only AFTER a muff shop replaced an OTA pipe too close. Even after stating they be mindful of.
You refer to "not holding air", and also "blowout". Whether just a leak or the latter, try to locate he failure first. The bag may have failed from closeness to exhaust than anything else. Mandatory to use the supplied heat shields on B/D bodies.
The legitimate dampening performance in any airshock will not come close to that of a quality separate shock. You're getting a low performing shock that is relying on the airbag to provide the majority of dampening - and also double-dutying as a spring. Stick with separates.
post #3 of 4 (permalink) Old 05-12-2017, 10:16 AM Thread Starter
OK. Thanks!
1995 Caprice Wagon
1996 Caprice 9C1
Winger67 is offline
post #4 of 4 (permalink) Old 05-12-2017, 10:33 AM
Replaced Airlift bags myself. They were about $60 from Airlift, IIRC
atlantadan is offline
