Front shock options - Chevy Impala SS Forum
post #1 of 17 (permalink) Old 06-06-2017, 10:58 PM Thread Starter
cashmoneyspeed's Avatar
Front shock options
I'm running a set of Intrax lowering springs and in need of new shocks. What are the current options for a lowered daily driver?
I have bell tech nitro drop shocks that have been great for the last 12 years but they are at the end of their life and summit doesn't have them for the front anymore.
cashmoneyspeed is offline
post #2 of 17 (permalink) Old 06-07-2017, 08:28 AM
I'm partial to the Bilstein's,and don't believe lowering makes much difference as the minimum travel is unchanged. Basically the piston inside the shock rides lower in the tube...
1slow96 is online now
post #3 of 17 (permalink) Old 06-07-2017, 11:13 AM
TGO
I ordered a set of Bilstein's because they seem to be the most recommended here.
TGO is offline
post #4 of 17 (permalink) Old 06-07-2017, 12:46 PM
juniorwatson's Avatar
I've been rolling on Bilsteins for the last 13 years, in two different cars. I was/am very happy with the ride they provide.
When I first installed them there was quite a noticeable difference from the cheapo shocks that were installed on my 9C1 when I first bought it.
After wrecking the 9C1 I transferred them onto the current ride in my SIG picture, and swapped those out for new in the fall of last year.
juniorwatson is offline
post #5 of 17 (permalink) Old 06-07-2017, 06:33 PM
I have stock length shocks on the rear of my wagon, and drop shocks on the front. The only issue I have is that the front tire comes off of the ground before the rear when I jack it from the rear. To change the rear tire, I have the whole side of the car off of the ground. The front wheel is about 3 inches off when the rear finally decides to lift. I can not put drop springs on the back, and still get the 255s out from under the fenders.
post #6 of 17 (permalink) Old 06-08-2017, 12:36 AM Thread Starter
Bilsteins seem to be the most recomended so I'm definatley considering them. $90 each from Summit. Any better pricing out there? Or opinions on other brands? Not looking for Gabriel "quality" but if there's co parable options for less, the vacation fund grows faster.
post #7 of 17 (permalink) Old 06-08-2017, 06:18 AM
I think I paid at $75 for mine. There was a recommendation on the forum from somebody. It has been a couple of years since I bought them. If all else fails, do an internet search, and check out the results for price.
post #8 of 17 (permalink) Old 06-08-2017, 07:37 AM
Way Too Easy Nowadays
Yah, my first set of Konis c.7BI took a letter to the company just to find a retailer. My 3 complete sets of Bilsteins have come from 3 different vendors. The last was shox.com I think.
post #9 of 17 (permalink) Old 06-08-2017, 07:49 AM
Originally Posted by cashmoneyspeed View Post
[SNIP]
TIRE RACK seems to have the best pricing as of this morning @ $85 & $66 each (FT/Rear).
This Thread may be of use to you as well.
post #10 of 17 (permalink) Old 06-08-2017, 08:42 AM
Got my set for under $300 from Bilstein Shocks, Sachs Shocks and much more: eShocks.com ,but that was a couple years back...
